Tip & How-To about Eaton Home Heartbeat Attention Sensor
Eaton Home Heartbeat Attention Sensor Description
The Attention Sensor can be used to instantly send a message to your alert address (cell phone and email). Choose from one of the 27 preset messages (or a custom message using the web portal) and click the button to send the alert.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the user manual at FixYa
Eaton Home Heartbeat Attention Sensor Logo
how to sent photos from pc to cellphone
If your laptop and phone have a bluetooth connection, connect them via bluetooh with PC suite or PC studio which can recognize your phone and send photos by exploring your phone.
Otherwise try cable connection. If both said are not possible, send photos to your email via mobile internet and download them from your email by accessing from your PC.
Sep 15, 2011 | Computers & Internet
I can not send emails !!
try to refresh page or repair connection
right click icon>repair
Aug 10, 2008 | Lands Phones
Hi I have Samsung B2100 mobile phone. When I receive a message, the sound is so loud. Can you please tell me how to control the volume.
menu/settings/phone profiles, select profile, then choose options at the low left corner of display. Here, you can adjust type of sounds you want and its loudness. Navigate to the right with your central button and here you are navigating downwards: 1. - message alert type chooser, 2. - message alert tone, 3. - message alert repetition, 4. - email alert type, 5. - email alert tone, email alert repetition, and finaly, 6. - alert tone volume. To enter into the submenu, first click direct the central button, and then choose the volume with left or right part of your central button. I am not a perfect english speaker, therefore I hope I was clear enough making this explanation.
Dec 15, 2010 | Samsung B2100 Cell Phone
email settings
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account
1. Select Menu > Messaging > Email > Settings > New account > Add.
2. Enter a name for the email account, for example, Home or Office. Select OK.
3. Select Connect using > Edit and select the data account you created earlier to use with this email
account.
4. Select Email address > Edit. Enter your email address. Select OK.
5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common.
6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK.
7. Select Username > Edit. Enter the incoming server username. Select OK.
8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you
want to be asked for the password each time you check new mail.
9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send
email messages. Select OK.
10. Select Advanced settings.
11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing
email messages.
12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and
select OK.
13. Select Download S&R. Choose what to download when receiving new email messages:
• Subjects only – receive information such as sender and subject before downloading the whole email.
• Up to size limit – receive the whole email. Select Size limit to set the maximum size to download
when receiving new email messages.
• Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files.
14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your
email server and check for incoming email messages.
15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to
disable the functionality. See Using push email for full email notification functionality on page 7.
16. Select Allow connection > Edit. Select Any network or Home network.
17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your
phone to be sent to an additional email address of your choice. This way your sent messages are
copied and can be saved for future reference.
18. Select Encryption > Edit. Choose whether your email messages should be encrypted.
19. Select Outgoing. username. If requested, select Edit enter the outgoing server username.
20. Select Outgoing. password. If requested, select Edit enter the outgoing server password.
21. Select Incoming port. If needed, change the port for the protocol you are using.
22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message
1. Select Menu > Messaging > Email > Write new.
2. Select To: to add recipients and select Add. There are three ways to add an intro sentence:
• Select Enter email address. to enter an email address.
• Select Contacts look-up to retrieve a recipient from Contacts.
• Select an email address from the last used recipients.
3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished
selecting recipients select Done.
4. Select Subject: to write the subject.
5. Select Text: to write the text.
6. Select Attachments: and select the attachment to add. Add more attachments the same way.
7. Select Continue.
8. Select Send to send the message or More to view options.
To receive and read email messages
1. Select Menu > Messaging > Email > Inbox.
• Select Send&rec when the inbox is empty or
• Select More > Send & receive to download new messages.
2. Select a message and select View to read it.
To reply to an email message
1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More
> Reply and select:
• Yes – to include the original message in your reply or
• No – to exclude the original message.
2. Write your message select OK > Continue.
3. Select Send to send the message or More to view option
Mar 08, 2010 | Sony Ericsson W350A Cell Phone
how do i set up emails on the nokia n95 8 gb
Tap the Nokia Menu Key and choose Messaging. Scroll down to Mailbox and click. You will be told ‘no mailbox defined. Define now?’ Choose Yes.
A wizard starts which walks you through the process. First choose Start with the left selection key. Choose your mailbox type using the scroll key and clicking to ensure the correct one is selected with a dot to the left of its name. If you have webmail or an email address from your Internet service provider, choose POP3. Click Next.
Type in your email address. Use the star key to pull up a symbols list so you can choose the ‘@’ symbol and the 1 key for the dot. Choose Next.
Enter your incoming mail server then choose Next and your outgoing mail server then choose Next. Now choose your ‘access point’. The choices will depend on which operator you are using at the time and you may need to ask your operator for the right information. You can get the phone to ask you every time if that might be useful. Make your selection then choose Next.
Now give this mailbox a name. Make it meaningful, something like ‘Gmail email’ if your email provider is Gmail, for example. When this has been entered choose Finish and you will be told ‘Mailbox setup complete. Settings can be viewed and edited in e-mail settings’. Click OK.
Personalise the settings
Now you need to tell the Nokia N95 how to behave when it is picking up and creating email.
When viewing the messaging main screen scroll to the mailbox you just set up and click it to open it. Now choose Options then E-mail settings. From here there are several sets of settings to make.
- Choose User settings.
  • In the space under My name type your own name. This will be used to identify you instead of your email address when the recipient device supports that.
  • Under Send Messages click the scroll key to choose between sending messages immediately they are created or at the next manual connection
  • Under Send copy to self click the scroll key to choose between copying yourself in to all emails sent or not
  • Under Include Signature click the scroll key to choose whether you want to include a pre-defined signature on all emails. If you choose yes, you are asked to define the signature now.
  • Under New email alerts click the scroll key to choose whether you want the N95 to tell you when new email has arrived. This is useful if you have chosen to retrieve emails automatically – see ‘automatic retrieval’ below.
- Choose Retrieval settings.
  • This is where you tell the phone how much of each email to retrieve. You might want to retrieve less if you think you will end up spending a lot on connection time. The choices are; to retrieve headers only, to set a size limit on downloads, or to retrieve messages and their attachments.
- Choose Automatic Retrieval.
  • If you need to get your email regularly then you can set up the phone to pick up messages at regular intervals. Choose Disabled if you want to pick up email manually
- Choose Connection settings.
  • Here you can change any of the basic email settings such as incoming and outgoing email servers and can give the phone your login password
Check out our Internet Settings page here
Oct 31, 2009 | Nokia N95 Cellular Phone
350 people viewed this tip
Top Eaton Home Security Experts
Lawrence Oravetz
Are you an Eaton Home Security Expert? Answer questions, earn points and help others
