Tip & How-To about Magellan RoadMate 1412 Car GPS Receiver
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
Magellan RoadMate 1412 Car GPS Receiver Logo
cannot recharge battery on my explorist 400 gps
I had the same problem with mine, the AC adapter fails really quickly. Try to go to Radio Shack and get the 3-12v switch able AC adapter that is 1 amp, and select the 4.5 volt setting. This setting is a whole .5 volts less than the one that comes with GPS, but its the Amps that matters. Make sure you get the correct plug with the adapter, I got the "B" plug and follow the directions that came with the adapter to match the right polarity, or you will fry your GPS. Also, the computer just supplies enough power to run the GPS, but not to charge it as long as you have the USB 2.0 ports.
Jan 24, 2009 | Magellan eXplorist 400 GPS Receiver
garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO CHARGE IT. IS THERE A POWER PLUG FOR ELECTRICAL OUTLET CHARGING?
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
My GPS won't turn on.
I had this issue also. When I got it out of the box, it had maybe 30 minutes of playtime without a charge before the battery went low. I used the USB it came with and found plugging it into my laptop AND desktop does absolutely nothing; even though the magellangps.com states the USB can be used as a charger on the PC.
It's been less than 8 hours since I've had it, and I have not gotten a chance to use the car adapter to charge it... I have a DC/AC unit inside my house which I am using to charge the unit and it works fine (incase you dont know what a DC/AC adapter is; its pretty much a lighter adapter that plugs into the wall).
MAKE A LONG STORY SHORT -
With my migraine starter experience with charging and powering on; I have read on 100's of Magellan 3250 reviews that cold tempratures cause these issues.
Other possible causes:
Battery is 100% dead = leave it in your car charging (HIDE UNDER THE SEAT!)
If the USB port plugged in charging in the car; if it is still not working, make sure that the FM part is also plugged in. I found that my GPS does not charge with just the USB end plugged... At least for me, it will only charge with BOTH ports plugged....
I hoped my novel helped... If it didn't; return your Magellan, and buy a GARMIN GPS. I have a Garmin that I bought for my hubby, and 2 years later, has never once experienced any issues.
May 09, 2008 | Magellan Maestro 3250 GPS
2,216 people viewed this tip
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
