Tip & How-To about Samsung HT-WX70 Theater System
Instead of resetting rear speakers each time.....
I have found a similar problem with the rear speakers on this unit (needing to be reset each time the unit was turned off), but found a quicker way around it.....with both the main unit off and the rear receiver off: turn on the rear speaker receiver, then the main unit. If the blue light on the rear receiver does not come on, turn off the main unit, and turn it back on again. This has worked for me ~50 times or so and has worked repeatedly. It's faster than going through the reset phase each time. Also when turning off the system, turn off the main unit first, and then the rear receiver. Sometimes I also simply leave the rear receiver on since it pulls only 4 Watts. Hope this helps any users.....(it also works on my boyfriends older generation model).
Samsung HT-WX70 Theater System Logo
Control station won't turn on.
That sounds like a hardware faulty i can only advise you to contact logitech.
Jun 04, 2009 | Logitech Z-5500 Computer Speakers
my main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
TX-DS575 reverts back to standby mode when turned on
You can find it out by yourself. I have the same device; therefore, I know that this device has a "test" function. Just unplug rear (surround) speakers at first, then test the rest of the speakers if the amp lets you do it. Hook up one of the rear speakers you regularly use to rear left or to rear right in order to test each rear channel. If one of them turns off the amp, you'll be able to understand which side feeding resistor does not work. However, if the amp goes to standby mode as soon as you hook up one of those speakers, you can alternatively invert the relevant rear speaker's input ports for a while. (+ to -, - to +) Don't forget that you have to hook up the other rear likewise. This will allow you to cheat your amp for a while, and let you test your channels without taking care of ohms.
Apr 20, 2007 | Onkyo TX-DS575 Receiver
1,683 people viewed this tip
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
