Tip & How-To about Samsung RM255LASH Side by Side Refrigerator
How to reset it out of demo mode
If your not getting any response out of your control pane you will have to do the following
The refrigerator may be in Demo mode which disables the compressor to save electricity when the refrigerator is on the showroom floor. To cancel Demo mode, press Freezer and Arctic Select Zone buttons for 8 seconds. You will hear a chime.
Samsung RM255LASH Side by Side Refrigerator Logo
code freezer demo
French Door: Why Does The Control Panel Display "OF OF" Instead Of The Temperature? If the control panel displays "OF OF" instead of the temperature, the refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save energy when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Disable Cooling Off mode by performing the following:
  • Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
Source:
Why Does The Control Panel Display OF OF Instead Of The Temperature...
Oct 17, 2014 | Samsung RF4267HARS Stainless Steel French...
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
how do I get samsung refridgerator out of demo mode
Your refrigerator might be in Demo Mode - also called Sales Display Mode - if it displays OFF or if the lights are on but the refrigerator isn't running. How to turn off Demo Mode varies for different models. Try one of the following:
-- Unplug the refrigerator for 60 seconds and then plug it in.
-- Press and hold the HOME key and HELP key at the same time, for 5 seconds.
-- Open the refrigerator door and then press and hold the ICE PLUS/ULTRA ICE key and REFRIGERATOR TEMP key at the same time, for 5 seconds. The door must be open.
-- Press and hold the ICE PLUS/ULTRA ICE key and the up/down keys, for 5 seconds.
-- Press and hold the EXPRESS FREEZE key and the REFRIGERATOR TEMPERATURE CONTROL at the same time, for 5 seconds.
Feb 13, 2011 | Samsung Refrigerators
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
floor model will not come out of demo mode.
If following dirctions from your owners manual does not do the trick. I would call for a tech to look at it. Every thing is control by dispenser board on a PSS26P
Jul 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
4,730 people viewed this tip
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
