Tip & How-To about In Win BL631.300TBL 300W Slim Desktop Case Black
How to wire (easy)
I just built my first machine today and had to figure out how I wanted to wire it... I found out that it is pretty basic and easy to keep the wires out of the cpu fans reach. The only problem I had that took me a little bit longer was I did not know that you have to wire the dvd specially through the fan.
So when you are building these make sure to leave enough room to reach to the DVD player other wise you will go through what I went through and have to re wire your machine.
In Win BL631.300TBL 300W Slim Desktop Case Black Logo
**** Fang wiring diagram?
chinese manuals not easy to find. but its similar to asian bikes. go to library thers many shop books wiring is pretty basic
Jul 03, 2014 | DONG FANG 250cc Sports Motorcycle
F3 E2 error code on my Maytag washing machine
I just had the same problem with my MayTag washing machine - F3 & E2 error codes.
I cleaned out the drain trap then proceeded to remove the top and rear panels to check the Temperature Sensor. The sensor was tested with an Ohms meter and found to be working properly.
I went over the wiring from the Temp Sensor and found that both black wires had been 'cut' under one of the zip ties near the bottom of the washer.
I had to reconnect them with marretts and presto; the washer works perfectly again. If you encounter this same problem - be diligent in going over the wiring. I missed it the first time around.
It's an easy fix for anyone who can strip a wire of the plastic coating.
Good luck :)
Feb 23, 2013 | Maytag MAH6500 Neptune Front Loading...
is a datsun z built in 9/77 a 78 as titled
On American built cars fusible links are 2 wire sizes smaller than the wire you are fusing. For example, a #10 wire would have a #12 fusable link. A lot of these things are pretty basic and common to all cars so it would probably work on your Z. Hope this helps.
Jul 10, 2010 | Datsun 210 Cars & Trucks
my ice maker 10amps fuse burn out when turn on the machine
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Jan 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
I have a 1E error code. Water supply is good to the machine. Not sure how to get to the filters. Don't want to break anything.
Ok found the filter in the front of machine, lower left hand corner. It was clean. Proceeded to remove front panel. But first turn of the power and I also turned of the water. Now I found that the wires from the wiring harness had imbedded themselves in the sound profing material. Its like a black thick tar. I guess during the drying cycle the tar heats up and the wires settle into the goo. As the door is opened and closed the wires are put under stress because they are now one with the door. I found a blue wire had broken. I soldered the wire and taped it. I also put waxed paper behind the wires to keep them from hooking up to the tar again. I will check that fix after a couple of months to see how the paper is faring. The machine works perfectly once again.
Jan 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
1,598 people viewed this tip
Top In Win Computers & Internet Experts
David Payne
David Payne
Are you an In Win Computer and Internet Expert? Answer questions, earn points and help others
