Tip & How-To about Asrock K7VT4A-Pro Motherboard
Asrock K7VT4A PRO
Please help i need procesor socket A (462) Athlon XP 3200+ 2400MHz 333MHz 512KB n/a ....
Asrock K7VT4A-Pro Motherboard Logo
Upgrade CPU on Matsonic MS8147C+
Unfortunately I think the Athlon XP is a 462 pin package and the MS8147C+ has a SocketA/Socket 462 socket for the CPU. The Athlon 64 3800+ is a 940 pin package and requires a AM2 socket, so this CPU will not physically fit.
Jan 18, 2014 | Matsonic MS8147C+ (N82E16813184008)...
I'm upgardeing my ms-7061's cpu from a 1.5 to 2.2
http://www.msi.com/product/mb/KM4M-V.html#/?div=Detail
Download > Manual >
CPU
Supports AMD Athlon / Athlon XP / Duran (Socket 462) processor.
(Socket 462 = Socket A)
Supports from 1100MHz to 3000+ model.
VIA KM266 Pro motherboard chipset - Front Side Bus support of 266MegaHertz.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
(Same specs as a VIA KT266A but with Integrated Graphics.
The 133MHz FSB support shown is doubled. AMD processors are 'Double-pumped')
VIA KM400 motherboard chipset -
FSB support of 266MHz to 333MHz.
(Same as KT400 but with Integrated Graphics)
VIA KM400A motherboard chipset -
FSB support of either 266MHz, 333MHz, or 400MHz
(Same as KT400A but with Integrated Graphics)
Looking at the Bottom/Right corner at the CMOS battery;
There are THREE sets of jumper pins to the bottom right edge of the CMOS battery.
6 pins towards the outside edge of the motherboard, 3 pins to the inside of the motherboard. (Left side of the 6 pins)
On the 6 pins in a row configuration, the top 3 pins is SW1.
The bottom 3 pins is SW2.
The 3 pins to the inside of them is JBAT 1
In the 3 pins for SW1 the bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Same for SW2. The bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Jumper on pins;
SW1 pins 2 and 3, SW2 pins 1 and 2 = 266MHz FSB support
SW1 pins 1 and 2, SW2 pins 1 and 2 = 333MHz FSB support
For the KM400A (KT400A) motherboard chipset;
SW1 pins 1 and 2, SW2 pins 2 and 3 = 200MHz FSB support
1) What is the model name, and model number of the AMD processor you are going to use?
2) What kind of Thermal Paste are you using?
3) What are you using to clean the bottom of the Heatsink with, and is the top of the Processor clean?
4) Are you following Anti-Static Precautions?
Post back in a Comment.
Regards,
joecoolvette
Oct 13, 2012 | Computers & Internet
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
ga 7vm400am motherboard
yes they are both 462 pin socket a processors and you have a socket a motherboard
Apr 30, 2010 | Computers & Internet
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
1,944 people viewed this tip
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
