Tip & How-To about LeapFrog Little Leaps Grow With Me Learning System
DVD/VHS COMBO SETUP
I have tried many times to get the code for my Magnavox dvd player/recorder to work successsfully. Finally, I went to the setup for my dvd unit and made one very important change. In the section that you select what thpe of dvd unit you have, I had to select player instead of dvd recorder. After I made that selection, I was able to get the controller to work with my dvd successfully. I quess the controller is suppose to work with a dvd player only and not with a dvd recorder. I have always had a dvd recorer and never a player only. I hope this tip will help someone to solve their setup problem.
LeapFrog Little Leaps Grow With Me Learning System Logo
I can't setup channels for Magnavox tv/vcr.
Good luck! We are taking our unit back. We are both professionals dealing with multiple intense things, then we get home and can't figure this stupid POS out.
May 28, 2009 | Philips Magnavox MDV530R DVD VCR
recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
channel setup for VCR recording
WHAT YOU HAVE TO DO IS GO INTO SETUP AND DO A 'CHANNEL SET' EITHER AUTOMATIC (WHICH DID NOT WORK ON MINE) OR MANUAL AND ENTER EACH AND EVERY CHANNEL YOU WANT TO RECORD. THIS IS TIME CONSUMING BUT THAT IS THE ONLY WAY IT WILL WORK - IF YOURS WORKS WITH 'AUTOMATIC' YOU GOT IT MADE
Jan 24, 2008 | Philips Magnavox DVD/VCR Dual Player
1,023 people viewed this tip
Top LeapFrog Toys Experts
thegtw
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
