Tip & How-To about Exercise & Fitness
How to pick the right treadmill for your home
Treadmill is a great equipment to help you stay in shape without having to leave your home. Matter of fact, it is the most beneficial working out equipment you can buy. However,before buying one, there are few things you need to make sure so you're making a wise investment. First of all, before buying one, test it! Step on it with your sport shoes and make sure everything is comfortable for you (the length and width of the belt, the hand rails, etc.). Second, make sure it has all the features you need. For example, if it is really important for you to know your heart rate at all time, make sure the treadmill has a heart monitor built in.Also, if you need to know how far you ran/walked and how many calories you have burned, make sure the treadmill is able to provide you with this information as well. Third, find a treadmill with at least 2.5 HP continuous duty motor, which will offer you a quality workout. Last, if the cost is an issue, make sure that the treadmill still fits your needs. Don't just buy a treadmill because it's cheaper than others, buy it because you know it will provide you with good workout, will last you a long time, and has all the features you're looking for.
Exercise & Fitness Logo
Do you have any tips for maintaining my hockey stick in good shape?
There is a seemingly random but great way to keep your blade more durable and harder to break down. Leave it out in the rain! Somehow this creates a sort of chemical reaction with the blade that is very beneficial to it.
Feb 06, 2013 | Hockey
healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
659 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
