Tip & How-To about Nikon Coolpix 4600 Digital Camera
Shows memory card write protected.....?
When I'm using any memory card, it shows write protected. Y does it happening so...? Ma memory card is fresh & not locked or somthing like that & it works in other devices...
Please help me sombody...
Thanks
By Jeffrey Paul Rodrigues...
Nikon Coolpix 4600 Digital Camera Logo
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
I have a nikon coolpix. It is continuously showing 'MEMORY CARD IS WRITE PROTECTED'. I cannot take any photos. Please help.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 17, 2012 | Nikon Coolpix S50 7.2 Mp 3x Optical Zoom...
memory card locked
Mar 24, 2012 | Canon Cameras
I ma getting memory card error - card locked on my canon SD 990.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 04, 2011 | Cameras
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
1,264 people viewed this tip
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
