Tip & How-To about Archery
Simple tips on becoming a better archer
A few simple tips you can use for shooting your bow and to improve your arrow grouping . first it starts out with a good stance your feet should be shoulders with apart but not over spread apart.you will want to face 90 degrees to either the left or the right of the target depending on your shooting hand .second your draw ,when you draw your bow the bowstring should sit right below the far outside corner of your eye..thirdly calming your self take a few deep breaths and hold your last breath till your ready to shoot and settle your pins (sights) on your target remember to use the right pin for the right distance.. fourthly remember not to drop the bow when you release the arrow.i dont mean actually dropping the bow on the ground but lowering your extended arm holding the bow forward to quickly before the arrow has time to release .dropping the bow can and will cause your arrows to drop too ...shooting your bow at longer distance will tighten up your arrow grouping at closer distances
Archery Logo
How fast can an arrow travel?
Recurve bow arrows can travel up to 150 mph. compound bow arrow can travel up to 200 mph and in longbow arrows the velocity is slower because the weight of the arrows.
Aug 26, 2012 | Betsey Johnson Archery
What's a typical arrow made of?
An arrow consists of a shaft with an arrowhead at the tip of the shaft. Arrow sizes vary from one another ranging from 18 inches to 5 feet, the flight velocity of arrows generally ranges from 100 to 300 km/h, depending on the bow power, and the condition of weather and wind.
Jul 30, 2012 | Archery
What is good to use for a target in archery?
You can buy archery targets, but they can range anywhere from $40 -$200. If you are looking to make your own, this is a fantastic article to read: Making Archery Targets from Livestrong.com.
  • I've used targets made out of hay bales in the past.
  • You can also make them from feed/grain sacks, packing filling, sand bags or old carpet.
  • The article above will give you instructions on how to make all of the types, then some.
Jul 09, 2012 | Archery
i want to buy shoulder pads of md-9000 (panasonic mini-dv format camera) from where i can buy that. i am from india
I suggest you use lightweight tripod instead of shoulder pads. Shooting stance using lcd monitor is very different from shooting stance using old cameras. connect the camera to the tripod and rest the tripod feet in you waist(Bind the tripod feet together), getting a clear view of lcd monitor. it is like carrying a flag pole when marching. using old shooting stance will only make you appear a crossed eye videographer!![:0)
Aug 31, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
738 people viewed this tip
Top Archery Experts
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
