Home | All Products | Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook | Tips
Having 2 Operating Systems in your PC (Windows Xp and Vista)
hytas
By Guru hytas
Rank: Guru
Rating: 86%, 59 votes
posted on Dec 13, 2008
Helpful
NOTE: This Tip can be Hard, I recommend Advanced Users Only.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we'll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don't just use the default. I chose roughly 10gb by entering 10000 into the amount.
This step might be confusing, because we need to change the cd-rom drive that's invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it's already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn't the end of the world, but it's not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we'll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it's easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you'd like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can't do the next step until we reboot. (you can try, but it won't work)
So we've come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like "XP". It would be wise to name the C: drive to "Vista" at this point as well.
Now you'll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like "Hit Esc for boot menu" you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don't try and install onto your Vista partition! See how much cleaner it is now that we've labeled each partition distinctly?
We'll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we'll need to use the VistaBootPro utility to restore the Vista boot loader.
Download and install VistaBootPro from vistabootpro.org
During the install you'll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the "Windows Vista Bootloader" and then "All Drives" radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you'll only be able to boot into Vista, but we'll fix that. Instead of manually doing the work, we'll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the "Manage OS Entries" tab and then click in the textbox for Rename OS Entry, and name it something useful like "Windows XP" or "The Windows That Works"
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying "unable to find ntldr" when trying to boot XP, you'll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can't find the files there, you can find them in the \i386\ folder on your XP install cd
You can share information between the drives, but I wouldn't recommend messing with the other operating system's partition too much… it might screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition "Data".
This works if you have the operation system "Windows Vista."
Comment by hytas, posted on May 23, 2009
If you used the tip I made and your PC has been broken. I am not the responsibility for this, you should thought of it before you did this.
Comment by hytas, posted on Jun 03, 2009
The Installation will only work if you have the authentic CD (With COA and Product Key). Without it, you will go risk and it will not work. It will show Bsod Instead. Be Aware.
Comment by hytas, posted on Aug 05, 2009
NOTE: I am not responsibility for any damages or lost operating systems to your system. It should be BLAMED on you. Have a think about it.
Was this helpful?
Yes
No
8 people thought this was helpful
Comment #1
posted on Jun 22, 2009
Truckerjohn
By Master Truckerjohn
Rank: Master
Rating: 81%, 6 votes
Do you still use Vista after having both. I use both. XP for Office and old software. Vista ia good for Media and gaming. The biggest problem Microsoft did with Vista is not being able to use old software. Can't wait to see what microsoft does next besides spending $100,000,000.00 on BING advertisement.
Comment #2
posted on Apr 24, 2009
none473
By Apprentice none473
Rank: Apprentice
Rating: 90%, 1 votes
It would be good to give some help in this tutorial regarding SATA controllers (XP not installing directly on AHCI), e.g. how to install both systems so the bios can stay in ahci mode (so no switching needed before booting vista or xp).
Comment #3
posted on Mar 28, 2009
ehsaasi
By Apprentice ehsaasi
Rank: Apprentice
Rating: 0%, 0 votes
Hi!
Plz help me I have satellite L305-S5908 I had deleted my windows vista 64 coz i want to change windows xp when i trying to setup win xp appeared error message there wrote check your hdd drive for virus or any new hardware. some thing like this plz tel me how can able to setup win xp.
also i want change NTFS To FAT For win xp how can able plz advise me, thank you very much
Comment #4
posted on Feb 13, 2009
abc0134
By Apprentice abc0134
Rank: Apprentice
Rating: 0%, 0 votes
Vista has handwriting recognition built in. XP doesn't. If you have a tablet, that's why you'd want Vista, too.
Comment #5
posted on Jan 03, 2009
g00ey
By Apprentice g00ey
Rank: Apprentice
Rating: 0%, 0 votes
Vista sucks, why would I bother?
Can you Help with these PC Laptops problems?
PC Laptops
i want to get the procedure for doing the sums in tally...
PC Laptops
assistance needed (black screen on laptop)
PC Laptops
how to fix msi black screen problem?
PC Laptops
no sound and not get it on
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My screen will not come on..it flickers with the normal...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
