Tip & How-To about Sharp AR-M205 Copier
How to avoid U2 error which require you to replace toner chips.
This tip is proven in our machines could it be AR, ARM or AL series. To avoid the error above refill the toner cartridge ahead of time before the triangular dots(toner low warning in red light) gives warning. Just estimate the level of toner by checking your page count from previous refill. Failure to do so will require you to replace the crum chips or the entire toner cartridge.
Sharp AR-M205 Copier Logo
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
system error in sharp copier machine
Chip error on the toner cartridge.
Maybe incorrect region cartridge or could just have done its life if the cartridge has been refilled.
Replace the toner cartridge
Jul 06, 2009 | Office Equipment & Supplies
SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Jun 30, 2009 | Sharp AR-207 Copier
sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
3,270 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
