Tip & How-To about Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum will not stay on/Switch will not stay "ON"
Dyson switches sometimes will not click in the "ON" position and will make you hold it in for it to operate. This has a basic fix that cost no money. Rubber mallet. hit the switch right on top like you were to turn it on but with the mallet. It may take several hits but fixes 90% of my switch issues. It is not a temorary fix either. I have seen one redo on those and it was due to cust abuse.
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
joint pops out
Very possibly there is a small black torx screw whack has fallen out or may just be loose. It holds that joint to the body casing.
The screw must be located and replaces in order to function properly but the ball covering your main motor has to be disassembled and sometimes removal of the motor is the easiest way to put the offending screw back into position.
Dyson has a 5 year warranty on many of their models so you may want to call their help line first. They can tell you where the nearest service center is and ,ay end up fixing the problem at not cost.
Nov 15, 2013 | Dyson DC25 All Floors Bagless Upright...
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
Aug 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
power switch will not engage.
Possibly the micro switch is faulty or the switch isn't in its proper position in the machine. It could be a cable problem too. An electrical continuity test (with the power off) should prove where the fault is. hope this helps.
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need basic instructions on how to operate a Dyson.
Copies of Dyson Operator Manuals are accessible on the Dyson website.  You will find everything you need there!
Feb 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
my DYSON DC07 upright vacum
the actuator in the switch is defective, you can replace just the switch. There are several places to get just the switch, just google "dyson dc07 parts" for places on where to get the switch.
Jun 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
598 people viewed this tip
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
