Tip & How-To about HP OfficeJet 6110 All-In-One InkJet Printer
Resolving the Paper Mismatch error on the HP allinone printer
Set the Paper Type settings to plain from the Printers properties window.
This will turn of the paper sensor on the Allinone and hence, you will not receive the error message again.
HP OfficeJet 6110 All-In-One InkJet Printer Logo
how do i change from normal paper to photograph paper
change the paper in the paper tray and then go to Printers and Faxes in Control Panel and right-click your printer and select properties and set the paper type from plain paper to photograph paper.
it`s as simple as that !
Nov 27, 2009 | Brother DCP-120C All-In-One InkJet Printer
can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
when I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP photosmart C4200 successfully installed and prints only on white paper. Unable to print on conqurer paper.
What is the problem - does it feed the paper or just nothing comes out when the paper is fed through to print
May 08, 2008 | Office Equipment & Supplies
4,727 people viewed this tip
Clive
Clive
Thomas F. Schneider
