Tip & How-To about Refrigerators
Danby Kegerators
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded. A lot of the errors are caused by a loose connection. There are 3 screws that hold the table top down, once you get the table top up you'll see the connectors to the boards and sensor, just start removing the connectors, straighten the pins and reinsert them. Also if you ever have an issue with the fan motor, that part is no longer used on these keg coolers, the replacement board assm no longer has a connection area for the fan so the fan can be disconnected if it causes you issues. Another handy trick is to put turtle wax over the touch pad were you select the temperature, then that way the spilled beer will roll off the touch pad instead of ruining it :-)
Refrigerators Logo
How to reset nokia mobiles life timer to ''0''
If there is no choice, then try this...this will completely reset your nokia 5700
Note: All your contact on your phone memory will be deleted...even your installed item will be reset... everything will be deleted...i think your memory card will not be formatted but still try to remove the memory card before trying this.
Ur phone must battery must no be low!!!
  1. Turn off Your Phone.
  2. wait for 30 sec, then
  3. press *
  4. press Green button(button that u answer call)
  5. press 3
  6. you must press all the three button at the same time and start the phone
if this dont work, try the same thing again and again...it will WORK!!
Jun 21, 2010 | Cell Phones
2,218 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
