Tip & How-To about Canon S400 InkJet Printer
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
Canon S400 InkJet Printer Logo
my canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
paper out canon pixma ip200
Either you have selected the wrong feeder, it can feed from the back or the front tray, the little green light shows which tray is selected. If you have paper in both, the feed roller may need cleaning since it gives that error if paper doesn't get picked up.
Sep 01, 2009 | Canon PIXMA iP2000 InkJet Printer
canon pixma mp190 driver for windows me
On January 18, 2007 Canon released new Windowme drivers for the following printers and multifunctions:
S100, S100SP, S200, S200SP, i320, i250, i255, i350, i355, S300, S330, i70, i450, i470D, i455, i475D, i80, S500, S520, S530D, i550, i560, S600, S6300, S630, S750, i850,  i6100, i6500, i860, i865, BJC-8200, S800, S900, S9000,  S820, S820D, i950, S830D, i9100, i990, i960, i965, i900D, i905D, i9900, i9950, MP360 Series, MP370 Series, MP390 Series, MP700, MP730, iP1000, iP1500, iP2000, iP3000, iP4000, iP4000R, MP750, MP760, MP780, iP5000, iP6000D, iP8500, DS700, iP90, DS810, iP1200, iP1600,  iP2200, iP6210D, iP6220D, MP150, MP170, MP450, MP500,  MP830, iP4200, iP5200, iP5200R, iP6600D
I have MP780 (print, scan, copy, and fax).  The released file mp780vst620en.exe does not install the multifunction MP780 correctly.
Does anyone know work around, please?
Thx.
Feb 15, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have just got a Canon Pixma iP4500 but as I use a Mac with leopard OS X 10.5.4 I have had great difficulty with the Easy-PhotoPrint EX that I had to download. When I want to select a photo to print only a few are highlighted and the others remain grey and unable to select. I have tried saving to the desktop etc but nothing works. Please help as the printer is useless unless I can select a photo to print. Thank you
Mac OS X v10.5 Compatibility For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300, iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
<Usage>
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000, iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Jul 17, 2008 | Canon Office Equipment & Supplies
2,272 people viewed this tip
old marine
old marine
