Tip & How-To about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
You NEED a service manual
At $ 90.00 plus per labor hour, paying about $ 60.00 for a harley manual from your dealer is gonna pay for itself in 5 minutes.
Lands Phones Logo
fixing power steering leaks in 2005 Toyota Highlander
The lines. you have 2.
high pressure and low pressure. combined, they cost around $400 at dealers but can be found cheaper online.
labor at a shop to replace both lines calls for 2.3 hours, so you will pay their cost per hour of labor.
plus shop fees and tax. (fees cover shop supplies like fluid, gloves, etc)
If the problem is the power steering pump itself, the average cost at shops for the part is $450 (part only) plus 1.6 hours of labor.
if the issue is the steering rack itself, you can find that part online for $350 on average.
If you just let the shop order the steering rack, they may hit you for $1,200-$1,400 just for the part, and labor times for that job is 4.2 hours.
Please note, the link I have attached may notbe the correct part for your toyota. You would have to search for the correct vehicle.
include engine size and other required info like "Toyota camry LE, 2.5L, front wheel drive"
Hope this helps.
2005 Toyota Highlander Power Steering Rack
Nov 30, 2016 | 2005 Toyota Highlander
What is the average cost to replace fuel pump assembly on 1999 olsmobile silhouette?
retail cost for the pump ( part# P74794M NAPA ) is $502.40 now that is retail your cost would be less the labor is 3.6 hours so i don't know were you live so i don't know the average labor rate but here it is around $80.00 per hour so that would make the labor cost $288.00 the most you should pay would be $790.40 plus tax.........GOOD LUCK
Jan 13, 2011 | 1999 Oldsmobile Silhouette
need to replace distributor in 1997 nissan pathfinder. how much would it cost?
parts vary from dealer @ $400 to junk yard @ $50
labor rate = 1/2
therefore you will pay 1/2 what ever the garage charges per hour PLUS the cost of the part
however, the garage "charge" for the part is generally twice the cost of what you pay
this is because when the "new" part fails they have to install it for free if under warranty
if you buy the part yourself... expect to pay no more than one hour service time usually less than $100
Sep 16, 2010 | 1997 Nissan Pathfinder
How many hours of labor will a dealer bill for replacing the flap door to the air conditioner? The Ford dealer said eight hours, which seemed ridiculous.
Tell them to show you the LABOR RATE MANUAL they are using to explain how many hours you will pay for job, multiply that by the LABOR RATE plus parts costs . Some jobs are labor intensive. Check it out. Hope this helps
May 15, 2009 | 2002 Mercury Mountaineer
surpentine belt
The labor shouldn't be more than two hours and the part should be around $75.00 max. So moderate shop will charge $95.00/hr for labor, a dealer closer to $125/hr. So at a cheaper repair shop, $265 plus tax, at a dealer more like $325 plus tax. Its an important component, but you don't have to get it fixed at a dealer. hope this helps
paul
P.S. Pep boys has cheaper labor and good mechanics.
Oct 30, 2008 | 2002 Dodge Durango
704 people viewed this tip
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
