Tip & How-To about Computers & Internet
How to make Desktops faster..
Can you remember when you use you PCs for the first time it runs very fast..... and after few months it is slowed down.. there is a solution for this.. if you open up the CPU and take out the RAM and clean it with cologne or something, your PC will become as fast as before... but it should not be repeated daily... :P
Computers & Internet Logo
how do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
Battery lose charge very fast. I had this problem a few years back and I had someone tell to pull the battery a certain way to kill the memory but can't remember the process
If the battery is over 4-5 years old, it probably needs replacing.
When you get a new one, make sure to run it all the way down at least once a month. Although the new batteries are not supposed to have a memory, I find that this procedure makes them last a very long time.
Aug 15, 2011 | Dell Inspiron 2650 Notebook
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
my bikes engine is running fast how to slow it down bajaj pulsar 150 cc from last few months local mechanic is unable to fix the problem
this sounds like you may need to clean out the carbourator with carbflux, you then should be able to adjust the idol which will overall lower your engine speed.
good luck and safe riding
Sep 07, 2010 | 2005 Bajaj Pulsar 150
4,888 people viewed this tip
David Payne
David Payne
