Tip & How-To about Dell Computers & Internet
Dell Vostro 1400, no image or display , broken NVidia 8400GS M
I have a Dell Vostro 1400 laptop, bought in 2007.
A few weeks ago, I turned on my laptop, put on a movie, and after a few minutes it froze, made weird noises, so I was forced to turn it off - it didn't seem like it was going to recover.
After I turned it back on, there was no image. I heard Windows boot up, but nothing on the screen.
I connected the laptop to an external screen, and what I saw was a very crappy picture, pixelated, and the colors were all distorted.
I found out that this was due to a broken video chip - the Nvidia 8400GS M that is hard-wired onto the motherboard of my laptop.
So, what to do?
Well you can't replace the graphics chip. You could potentially buy a new motherboard for this Dell model, but it's not worth it.
In the end, you're going to have to buy a new laptop, because the integrity of the connections in the motherboard and graphics chip have been compromised.
However, there is a temporary fix for this problem, which will restore the image.
You have to put the motherboard in the oven for 8 minutes, at 200 degrees celsius.
That's right. Bake the motherboard.
Take apart the laptop completely, expose the motherboard.
Take off the heatsinks.
Take off the plastic shielding stickers.
Put some aluminium foil on a platter for the oven.
Then make 4 identical aluminium balls, and place your motherboard on those in the platter.
Pre-heat the oven to 200 degrees.
Then put in the motherboard.
After 8 minutes, turn of the oven, and crack the door open a little.
You don't want to take out the motherboard right away - otherwise you risk cooling the solder connections too quickly and they will crack.
Leave it to cool gradually for about 30-40 mins.
Then reassemble your laptop and it should work.
NOTE: this is a temporary solution that will give your laptop another 1-4 months to live. In that time I recommend shopping for a new laptop.
Because the problem will return.
Computers & Internet Logo
i have a vostro 1400 model with a nvidia 8400m gs GPU. my laptop turns on the screen too, but remains always black. overheating gpu brings it to life, but only for a week. is there any solution?
Based on the symptoms provided, the issue is hardware related. Installing the Drivers such as Video card, BIOS update etc will not resolve the issue efficiently..
Jul 04, 2010 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Dell Vostro (with Vista) Speakers don't work...
Once any OS is installed over old one or clean install is done one of the drivers that has to be usually reinstalled is sound drivers. You will have to go to dell.com and choose support and downloads and find ur system and install the new vista driver. This should fix it. Good luck.
May 08, 2010 | Dell Vostro 1400 Notebook
My vostro 1400 laptop does not detect the battery
hi, gmotian:i think the battery does't match your laptop,i suggest you buy a new one battery from http://www.adapterlist.com/dell. which is an online shop,exporting various models replacement laptop battery.best luck!
Aug 20, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
Blue Screen on Dell Vostro 1400
OK you can try a couple of things.
1. On booting the Laptop, hold down F8 key, then choose "Last known Good Configuration". Windows may now start correctly.
2. If this doesn't work, do the same, but choose "Boot into Safe Mode"
If neither works you may have to repair Windows...
Dec 26, 2008 | Dell Vostro 1400 Intel Core 2 Duo T5270...
2,049 people viewed this tip
Clive
Clive
Alun Cox
