By
rab74
Rank: Apprentice
Rating: 80%, 3 votes
posted on Dec 02, 2008
Problem - You put the DVD recordable media in and it takes about 30 seconds before it identifies the disc and says Initialize Disc?
You click OK and it takes the full 2 minutes only to stick after 2 minutes and do very little but spin. Disc will not eject unless power is removed first.
Disc will read DVD's ok.
Solution - Clean the lens with a cotton bud and Isopropyl Alcohol very gently. Shine a flashlight onto the lens to see if the reflection is clean. If not the soft wood of a match stick with a small piece of clean silk can be used to rub the lens with as little pressure as possible.
The DVDR should read and the initialize, although it says will take 2 minutes, should jump to the end quickly and the DVDR+ sign appears in the corner.
(My problem first occurred after some painters were sanding in the house and the machine got full of dust, but the clean did not last long and it turned out there was a smudge on the lens which you could not see without the flashlight. Once it was removed the recorder was back to working order.
Can you Help with these DVD Players problems?
LG RC797T
how do i transfer copy protected vhs to dvd on lg rc797t,...
LG RC797T
Need the various options codes available and what they...
LG RC797T
Seemingly randomly the drive will read and play a disc....
LG RC797T
My LG RC797T suddenly "lost" all previously...
LG RC797T
My DVD drawer opens and closes on its own. I had to unplug...
