Tip & How-To about Samsung HTQ100 Shelf System
Remove Regionalisation
Hi All
After having my HT-Q100 repaired by an official Samsung repair centre, I was unable to play any DVD's - even UK ones!
So I phoned Samsung, they said I should return it to the repair centre for it to be fixed.
I couldn't be bothered to waste time on this yet again, so I logged onto Moneysavingexpert.com and found that you can remove regionalisation on DVD players and it's totally legal!
Therefore the following instructions are for removing the regionalisation on the Samsung HT-Q100 so you can play any DVD's! I've just carried this out and it's fixed the DVD problem and can once again play DVD's!
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
The above was courtesy of the link at: http://www.videohelp.com/dvdhacks/samsung-ht-q100/7502
Qubix
Samsung HTQ100 Shelf System Logo
hi my ht-q100 dvd player not working saying there is no disc even if the disc is inside
Often helps to blow in the hole where the disc goes. Blow hard a few times then try disc again.
Jan 17, 2010 | Samsung HT-Q100 System
I currently have a DVD in and it won't eject. I have a Samsung HT-Q100 System
Turn off the DVD player completely. You MAY have to turn off the tv too. Let sit until you count to fifteen! Turn back on, tv first, then DVD player. You should be able to eject the disc then.
Jan 01, 2010 | Samsung HT-Q100 System
unable to switch on HT XQ100 Home thatre system - all I get is a NO ENTRY sign on the front of the base unit instead of the usual D.IN. By continually trying the on off switch will usually / eventually get the unit to turn on and it is fine until you try again the next time.
thought I was going to get a response from FixYa - your website said queries answered with no charge - if I had wanted the premium service I would have gone straight for it but as there was no hurry I decided to go for the other option, it does not appear I will receive a solution from you and have therefore taken my unit back to the Samsung service centre for repair.
Jan 28, 2009 | Samsung HT-Q100 System
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
samsung ht q100
No it does not. It will upscale regular DVD's to HD resolution, but that's an electronic trick. You'll need to buy a BluRay player to watch high definition discs.
The HD-DVD standard has been abandoned by Toshiba, so the Sony players are the one's to look for.
Dec 08, 2007 | Samsung HT-Q100 System
1,944 people viewed this tip
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
