Tip & How-To about All-Pro Forced Air Kerosene Space Heater SPC-K75
Forced Air Kerosene Space Heater Spark plug
I have an older COOP 50,000 BTU forced air kerosene heater. I tried burning #2 in it. Result was rapid fouling of the spark plug. I removed the ground electrode from the plug allowing the spark to jump to the shell. It has never fouled the plug again, runs perfect.
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
I have universal 150,00 btu/hr and it wont ignite, the nozzle sprays a mist but no spark?
You may have a bad transformer that sends the electricity to the spark plug. Have you tried a new plug?
Jan 10, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
my kerosene 50,000 btu reddy heater fires up for about five seconds and then shuts off. I put no. 1 kerosene in so it burns cleaner. It's 2/3s full. the drywallers used it last so it's a little dusty. Why won't it keep running?
There is a sensor inside that tells the heater that the flame is lit...if it doesn't "see" the flame it will shut down...this may be caused by the filter in the rear being clogged and it is not allowing the pump to produce enough pressure to ensure a good flame or the pump inside may have sucked up some debris and is now not producing the proper pressure required. Another possibility is that there may be enough dust on the sensor itself to cause it to not "see" the flame...if you take the cover off you can find this sensor...it will have 2 wires coming off of it and it looks like a photocell...it should be located just in front of the jet where the fuel comes out...a word of caution...the ignitor(and the spark plug looking thing) have very high voltage on them(around 5000Volts) so I would avoid touching these parts while in operation.
Dec 08, 2010 | Reddy Heater 60,000 BTU Kerosene...
older torpedo style kerosene 50,000 btu smokes
clean out the fuel nozzle and if it wont burn cleanly, replace it.
Jan 03, 2010 | Heating & Cooling
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
768 people viewed this tip
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
