Tip & How-To about Hoover Washing Machines
Hoover Optima 1400 A+aa
If your Hoover washing machine is giving program problems,before you call a repair man, if the program knob can be pulled off, revealing contacts, get yourself a can of servisol contact spray, and spray and leave a few minutes, than wipe with clean soft cloth, you might save yourself money, unlike me, it cost me 120euros for 5 minutes of the guys time, and I had the Servisol in my workshop.
Washing Machines Logo
Hoover washer will not fast spin
This problem is usually caused by a faulty on broken program card. This card tells the washer what program is running if this is not working the washer will spin and spin. Contact your local repair shop if it is under warranty this is covered usually by the warranty.
Aug 18, 2015 | Hoover Washing Machines
nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
Mar 21, 2012 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover washing machine gets stuck between program 9-10
You have a fault inside your timer, These can be repaired but due to the age of the machine it may or may not be worth while repairing, The machine is sticking due to a contact issue somewhere inside the timer.
Mar 08, 2012 | Washing Machines
I HAVE SOMETHING STUCK BEHIND DRUM IN HOOVER 200M WASHING MACHINE HOW DO I FIX
Hi, I am having the same problem atm and was wondering if you fixed it?
Where there any damages to the machine and how much did it cost to repair if you called a repair man?
Thank you
Claire
Nov 20, 2010 | Hoover Washing Machines
Wont Stop
probably the timer pcb has gone faulty.
Jan 12, 2008 | Hoover AL120 Front Load Washer
2,467 people viewed this tip
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
