Tip & How-To about Panasonic Televison & Video
HOW TO ENTER SERVICE MODE MENU TO PANASONIC TVs
This is the way to enter service mode menu to most of the Pansonic TVs.
1. Press and Hold Down the [Vol-ve] key, on the front panel of the TV set.
2. Press "Recall" button on the remote control three times.
The service menu window will appear.
3. Use digits [1] & [2] keys on the remote control to navigate Main Menu items.
4. Use digits [2] & 4] keys on the remote control to navigate sub Menus.
5. Press [Vol+ or Vol-ve] keys on the remote control to change the data value to selected item.
6. Power OFF the TV, by its main Power ON/OFF switch to save the adjusted value into memory and to exit from service menu. When you switch ON the set for the next time, it will come alive with adjusted parameters.
Televison & Video Logo
I have replace the front panel of my kithchenaid fridge model KFIS25XVMS9 code 1813 but it doesn't work.
It is easy to make a mistake in the instructions below so pay close attention to the instructions or they will not work until you do.
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Aug 26, 2016 | KitchenAid Refrigerators
I have Direct TV. I need to program, my remote to it. I need the code for model # SK-32H650G?
https://support.directv.com/app/answers/detail/a_id/4028/~/how-to-program-directv-remote-control
full directions:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 1, wait two blinks
4. enter 1
5. press and release VOL UP
6. point the remote at the tv and keep pressing and releasing the CH UP key, if and when the volume changes
7. press select to lock in code
Jul 04, 2015 | Westinghouse Televison & Video
I can't enter service menu on Sharp TV 60LE751
Give this a try...
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu
Mar 22, 2014 | Televison & Video
5,996 people viewed this tip
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
