Tip & How-To about Epson Stylus C46 InkJet Printer
C46 Squeeling Noise
All printers are greased on all moving parts apart from where the paper has to pass, as they don't want grease to get on your paper. That is why a lot of printers squeel, it's because some rollers are not lubricated. Particularly the final roller on the Epson C46. You can see this roller by looking through the paper exit tray (where the paper comes out). It is usually black in colour and has 9 bearing points which are just plastic against plastic and these rub together causing plastic dust to be created and this is what causes the squeeling.
Simply dab a tiny smear of grease or oil on the top of each bearing point (each is open at the top) and your noisy printer will become a quiet printer.
Please note that 8 of the bearing points are easily accessible, but the 9th being the far left one as you look in from the front and is about a half inch behind a grey plastic side wall. You can get to it with a small flat head screwdriver, so use one of these to apply the oil or grease.
Please be careful to only use a tiny smear of lubricant or the excess will drip or fall on your paper exit tray and ruin your paper.
Epson Stylus C46 InkJet Printer Logo
my printer prints some matter and then gives message for paper jam
Hi Mr. Khan
This is a problem with the carriage rod. Try to lubricate the rod with a little silicon grease to make it move freely. Normally it happens after some usage that the grease provided on the rod by the company dries up. Do not put more grease as it may drop on the circuit boards.
Jul 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
We got a Kenwood Chef mod a901 as a gift but no service manual. This mixer has seen a lot of usage during its lifetime and I don't know whether it has been serviced regularly. Does it need regular servicing, or will it suffice to just grease the easily accessible moving parts? Any info will be greatly appreciated. Many thanks in anticipation.
The parts that may require service after a very long tim would be the gear box which would require a clean out and refill with grease and the output shafts which can be wiped clean and given a touch if grease as well. The motor bearings could do with the same treatment and all this calls for a strip down of the mixer. However, if there is no perceptable play in the drives and no strange noises, the unit is possibly best left alone with just the minimum lubrication being applied as you intimate.
Jul 12, 2011 | Kenwood Food Processors
kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
paper not moving forward
please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
Sep 18, 2007 | Sharp EL-2630P Calculator
3,518 people viewed this tip
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
