Tip & How-To about Xerox Computers & Internet
Replacement drivers for the Phaser 7500
The print drive for this printer is horrible, and causes functunal print issues. The best and simplest work around for this is to not use the phaser 7500 driver. Answer coming next . . . Use the Okidata C9500 print driver. It works perfectly for the Phaser 7500. Now you know how to make it print properly
Computers & Internet Logo
My printer will not print. There were no cartridges in it for about a year. I have installed new cartridges but it will not print.
There are several solutions depending on what the issue really is. The simplest of them is to run the print head cleaning wizard, which comes with your printer software installation CD. This have only a slight possibility to solve the issue, but since it's very simple, you can have a try.
The next solution is applicable when you have ink clogged in your print head. It may happen due to several reasons like leaving the printer unused for a long time or if the print head was kept in inverted position during packing and storing etc. In that case, remove the print head, and place it in warm water (1/2 to 3/4 inch) for a few minutes. Care should be taken to avoid too much water getting into the print head. You will see ink leaking out to the water. Take the print head out and put it back in the printer after wiping and see if it works. You should try a few test prints as the first few prints will not be clear due to the water in the print head.
If none of the above two works, then you can't go for a economic repair. The best thing now is to replace the print head. But, before doing all this, try contacting your dealer or the HP, if the printer is still under warranty. They will solve the problem for free if it is so.
Hope this will solve the issue. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
paper in printer is jammed up
What specific model of printer do you have?
If it's jamming, make sure paper type is identical. Make sure the quantity is enough for the printer tol hold. Try to reduce the amount and clean the rollers of the paper tray/feeder using alcohol.
Jul 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
1,185 people viewed this tip
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
