Tip & How-To about Microsoft Windows XP Professional
File Searching in XP
Windows XP typically does not allow your system to search for file types that Windows does not recognise.
For most users this really doesn't pose a problem as they will rarely, if ever, need to search for unusual file types. If you are a software developer, however, you may find that your code routinely uses files that have an extension that Windows simply doesn't recognise.
This is easily rectified by adjusting the following registry key, using regedit set:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ContentIndex\FilterFilesWithUnknownExtensions] = 1
Note: Using the registry improperly can impare the use of your PC, so it is advisable to make an export of your registry before making any changes.
Microsoft Windows XP Professional Logo
my computer is saying the sims 2 double deluxe installed but i cant find it no where on my computer and when i put it in the install comes up and it says its already installed but cant find it
The game files are in the Program Files folder of your C drive. You can actually perform a file search from File Explore. However, if you are talking about your saved games, then those will be in your User folder in some location depending on which Windows Operating System you have installed.
Mar 14, 2011 | Computers & Internet
Seagate Barracuda 7200.7 160GB
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
JVC-MG26EK WITH APPLE MAC DONT RECOGNISE THE MOOVIE FILES OR A WINDOW POPS WITH "CHOOSE APPLICTION " I HAVE PROPLEMS WITH WINDOWS XP ALSO  IS THERE A NEW SOFTWHERE AVALIABLE ????
search the on screen menu on the JCV and check the output file type and output via firewire. Macs are good with most video types but likes firewire for video
Feb 23, 2008 | JVC Everio GZ-MG21 Camcorder
366 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
