Tip & How-To about LG KG300 Cellular Phone
Connect your mobile to pc for internet
Hi i am Rajkumar...... after that just install your mobile modem connect your mobile with pc select com port option of your mobile than you find found new harwre in your pc install it now open your my computer ----->right click --->>>properties--->>harware ----------->>>>device manager---------->>com port-------->>> now see which comport is installed here......... now go to control pannel -------->>>phone and modem------->>>modem-------->>>>>>>.add-------->>>>next---------->>>next----->>media tek or mtk gprs -------->>>select the same port which you see in device manager comport---->>>>>.installed it........ now go to control pannel ------>>>network connection ----->>create new connection----------->>>>next----------->>>>>>>connect to internet------->set up mannually-------->connect using daial up modem----------->>>>>>select modem of same com port---------->>>write ur name---------->>>write *99***1# or *99# -------->>>select next--------->>>>next------->>>>>>finish
now go to control pannel -------->>>network connection--------->>select ur name and enjot your internet........... if there is also any just reinstall ur modem ,restart every thing and dial again....... bye .........
LG KG300 Cellular Phone Logo
How to connect micromax q5 with PC and how can i do internet by Aircel gprs. I saved aircel gprs settings as Name: aircel net APN:aircelweb Username: Blank Password: Blank , in my q5 phone i can use internet through web and also through Opera mini but when i am connecting it with my pc and installing driver its shows found new hardware, then what are the steps do i need to do ... Plz reply me soon.
Below goes the instructions to connect..
1. First install the USB Cable driver, please do not connect your cable to your mobile until you installed it correctly. You will receive a message USB cable driver installed successfully.
2. Then connect your mobile with your pc. A message on your handset appears with three options.
Mass Storage, COM Port and PicBridge. Select COM Port.
3. Now your PC will detect a new hardware found and a window will pop up. Select the third option..No, Not at this time then click next.
4. Select installed the software automatically and click next. Wait for 10-15mins depending of the speed of your PC, until window finishes installing your modem to the com ports. if a pop window appears in between then just click "continue anyway tab". Selecting this will not harm your computer.
5. Now you will see a message "Your modem has been successfully installed on com 4 or what ever the number it has."
6. Now copy your PC suite to C drive. Actually Micromax Q3 PC suite doesn't have the installer exe. So you have to copy the whole folder to the root drive of your PC.
7. Run the PC suite exe. and go to the settings tab on the left hand side of your PC Suite. select the drop down for COM4 or the COM number on which your modem was installed and wait for few seconds..
That's it..now you can see your status bar it will show you "Connected"
Enjoy!!!!
Mar 18, 2010 | Lands Phones
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
unable to detect modem for nokia 6070
download 6020 cable modem drivers from http://europe.nokia.com/A4144316 (yeah, no modem drivers for 6070). then go to device manager and update modem drivers to downloaded one.. that only will do.
Jan 25, 2008 | Nokia 6070 Cellular Phone
nokia 6101 driver
hi,
     to connect via cable..u frst need to install the drivers of cable & than u need to go to control panel>phone & modem options> in that click on modems tab> in that check for ur hndset modem. If u dnt get 6101 modem than click on add new modem.in than select dont detect my modem i will select it from the list...in that either u will get nokia or standard modem..if ur geting nokia than select 6101 model & press next..if ur geting standard modem than select 9600bps modem..after select either of them select the port in which u want to install the modem ..it should be more than 2..after that u can connect
thanks
Gizmo11
Oct 22, 2007 | Nokia 6610i Cellular Phone
2,210 people viewed this tip
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
