Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Solution to Virtual Memory Too Low Problem
This problem was reported by one of our readers that in spite of having a sufficient amount of RAM, he is running out of Virtual Memory and his Windows PC gives the following error:
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
This is a common problem and you may have seen it if you are trying to open many heavy applications at the same time like Microsoft Office.
Let’s see what the causes are and what can be done at this stage.
Windows XP or Vista uses the concept of Virtual Memory that aims at providing the additional memory from the Hard Disk if most of the RAM of the computer is already occupied. This memory used from the Hard Disks is called Paging File. Windows reserve some part of the memory for this purpose only (this is one of the reasons why we see less memory than specified on the hard disk).
Virtual Memory also known as Page File or Swap File can be located at C:\pagefile.sys (it is system hidden and can be viewed if you Uncheck the option of “Hide Protected Operating System Files” inside Folder Options).
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
My computer runs slow. It takes a long time to boot up. Occasionally I get a message that virtual memory is low. Is there something I can do myself?
Hello
Yes, this is a very common problem for computers which does not have the sufficient amount of ram installed for the software the machine runs.
At the link below you will be able to read a couple of tips on how to improve your computer speed.
Click HERE.
Kind regards
Andrea
Sep 19, 2010 | Dell Microsoft Windows XP Home Edition
"Virtual Memory Low" error message on IBM Thinkpad T30
Right-click on "My Computer", goto "Properties".
Click the "Advanced" tab, and click the "Settings" button under Performance.
You will see Virtual Memory under there. Click the "Change" button, and switch to "Custom size".
Initial size: 500
Maximum size: 2096
Click the "Set" button, close everything out and restart the computer. You should notice a difference. If you have any questions, please feel free to comment! Please don't forget to vote! Happy Thanksgiving!
Nov 25, 2009 | IBM ThinkPad A31 Notebook
My Vaio Laptop VGN-FW390 can not hibernate properly and sometimes restart during hibernation or sometimes shows an error page when I turn it on after hibernation. ???
Try to Reformat your Laptop and install all the driver. Be sure on the control Panel or click properties then at the appearance tab be sure that on the hibernate tab or on the enable hibernation is checked.
Oct 08, 2009 | Sony VAIO VGN-FW390NAB PC Notebook
637 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
