Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
my task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
pendrive is write protected......!!!!
1st your pendrive
your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
If the above method is not work
Try to format in other operating system like vista or in 7
but not in xp because in vista and 7 you can force format your pendrive..
2nd your task manager
visit the website and download task manager and registery fix (it is only work in windows xp)
http://www.2shared.com/file/10418643/7fd29ae/restore_all.html
Dec 24, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
folder option is missing and regedit disabled
u need to format ur system or can run a full system scan
Apr 19, 2008 | Microsoft Windows XP Professional
folder options in my control panel and in tools menu
hi friend
ur pc has been infated by viros taht y the folder option remove so u have to do this dwonlaod the latest updated antiviors form the intenet downlod it install ur pc scan form it see the link for more info
http://maintainyourpc.blogspot.com/2008/02/registry-editor-disabled-by.html
http://maintainyourpc.blogspot.com/2008/02/task-manager-has-been-disabled-by-your.html
after removing viorus here is link for ur restor ur folder optin link downlod soft & install it
http://www.raymond.cc/blog/archives/2007/06/28/restore-task-manager-regedit-and-folder-options-disabled-by-virus/
Mar 28, 2008 | Microsoft Office Professional 2007 Full...
task manager disabled
You may get into advanced boot options by pressing F8 key during the boot, choose "Safe Mode". Choose Administrator account and change the user settings accordingly. Since you have concluded it caused by Virus, obtain a reliable antivirus and antispyware software. If issue persist perform system restore by choosing the earlier date that system was working fine. If you need further assistance please post your question.
Good Luck
Feb 20, 2008 | IBM ThinkPad T30 2366 Notebook
550 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
