Tip & How-To about Lands Phones
Chosing Automobile Engine Oil
There are many types of oil on the market from many different makers and each will claim to be the best oil for your car. They'll claim to have the best year-round protection even when they don't know where you live. As engine technology improves, perhaps the oils will improve too. Until then, here is this...
When chosing oil for any type of engine, the important thing to consider is the thickness of the oil which is identified by the oil's "weight.". The higher the weight - the thicker the oil. Got it?
Engine oil serves two functions. It lubricates the moving parts, and it helps keep the engine from overheating by reducing friction between those moving parts. When you pour oil in your engine, it drains right down to the bottom and settles in the oil pan. When you start your engine, that oil is basically splashed around to coat whatever is near.
Oil behaves like pancake syrup. When it's warm, it's thin and runny. When it's at room temperature, it's thick and not quite as tasty. A thin oil (low weight) it will drip back down into the pan more quickly than a thick oil and therefore won't cling to those moving parts quite as long. The hotter the engine gets, the thinner the oil gets. So, you need an oil that will be as thick as your engine can handle so that as it heats, it won't become too thin. If you live in a climate that is hot year-round, use a thick, high-weight oil.
Some will say that if the oil is too think, it won't run down fast enough to carry away the heat from the engine. Yes, that is true. However, oil is not designed to cool the engine. Oil is designed to prevent heat buildup. There is a big difference. Oil is not a remedy for heat, it is a prevention of heat.
Your car's engine does not get hot from the small explosions of gas burning inside the engine. That heat is expelled with the exhaust air. Your car's engine gets hot from the heat that is generated by the friction of the moving parts within. If you reduce the friction, then you reduce the amount of heat that is generated. That is what oil does. Therefore, it needs to coat, stick and stay put.
Lands Phones Logo
what is the difference between Fiberglass spring and carbon fiber?
Both types are very similar. Even though the carbon fiber claimed to be lighter, stronger and springier, I can tell you that don't really feel the difference. Both are fine. The most expensive stilts on the market - The original power skip spring, still uses fiberglass.
Jul 09, 2012 | Sport & Outdoor - Others
WICH OIL IS RECCOMENDED FOR THE JAGUAR S-TYPE 200HP 2002?
CASTROL IS VERY GOOD OIL, I RUN IT IN ALL MY CARS AND TRUCKS. YOU SHOULD USE 5W20 INSTEAD OF 5W 40, THE 5 40 IS A LITTLE THICK FOR THIS CAR.. BUT THE BEST OIL ON THE MARKET IS ROYAL PURPLE, ITS A LITTLE PRICEY BUT WELL WORTH IT..I HOPE THIS WILL HELP YOU.. GOOD LUCK KEITH..
Mar 12, 2009 | 2000 Jaguar S-Type
1,549 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
