Tip & How-To about Kodak Office Equipment & Supplies
PAPER JAM MESSAGE
Yes you need to CLEAN the long plastic roller with COTTON BUDS and surgical alchohol /IPA worked for me , was about to chuck the PRINTER on the TIP , but workd great now :) !!!
why does my sony sy no disc
clean the laser it may need a manual clean take it apart till you see the lense i use vodka or surgical spirit don\'t press on the laser i use cotton buds :)
Dec 23, 2013 | Sony Audio Players & Recorders
paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 16, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
paper jams
hai
you can clean your printer roller by using some waste cloth. follow these steps.
1. remove the cover (paper jam door) in the back side of your printer
2. there you can find the rollers.
3. use some little iso propoline alcohol (IPA) to clean the roller
Aug 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have a Toyota Scion with a Pioneer T1805 that is giving me a Error 4 Message perodically which does not allow me to use the CD player. Help Please!
The most common problem of error messages is the lense and the roller.The roller is that moving back and port bringing the lense set,had already many dirt,that stock up of moving the roller.You better take out the unit from your car and open it .You clean the roller by using a lighter fluid or desame kind of that fluid and clean the lense with a cotton buds ,soak the cotton buds with a little plain water and after that , use a dry cotton buds to dry it out and in the roller take the old grease in the roller and replace it with a new grease .Use a type-A class grease.If you finish this all,i assume you that performance will be better.
Jun 14, 2008 | Pioneer Audio Players & Recorders
Epson C43SX
try this: delete epson c43sx drivers then reinstall them then go to the Epson web site and look for an updated driver, if that does not work take the whole cartridge harness out, under the harness you will see a contact board and you will see another one on the printer, get cleaning solvent and a cotton buds, dip cotton bud into the cleaning solvent, turn cotton buds sideways and clean the contact boards on both the cartridge and the printer, clean until and refresh cotton buds until you get a a clean cotton bud tip, let it sit for 5 to 10 minutes, reinstall the harness and try again, if that does not work you could have a main board problem contact Epson.
Apr 23, 2008 | Epson Stylus C43SX InkJet Printer
3,195 people viewed this tip
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
