Tip & How-To about Corona 23-DK Compact Heater
Wick won't light
I didn't realize how quickly condensation can enter the tank. Condensation will ruin the wick permanently, even a brand new wick.
To avoid condensation, do NOT empty the tank unless you are replacing the wick, or some other repair requires it. Likewise, do NOT burn the kerosene out, for the same reason: condensation.
When the tank is filled enough, condensation can still enter but the wick will be able to burn and you won't know the difference. But as soon as the kerosene is gone, all the wick has is water.
STORAGE:  When you burn out the kerosene to store it, condensation can enter and you will not be able to use the wick again. So unless it's necessary, don't burn out the kerosene.
If you have to store the heater in a place that requires the tank to be empty, dissassemble the heater before you use it again and make sure the tank is completely dry and contains no water BEFORE you use it again.
I think but I'm not sure, that the tank must have been designed to let some condensation fall to the sides, or somehow get out of the way. But I'm certain this doesn't last because condensatiion is inevitable and it will accumulate.
Corona 23-DK Compact Heater Logo
condensation around refrig walls
Either the door gaskets are not sealing properly or the doors are not completely sealing. The moisture is from air entering the refrigerator and the moisture in the air condenses into water. Check your doors and gaskets for leaks or gaps.
Sep 14, 2009 | Refrigerators
condensation in light housing
Lance,
You won't be able to get the condensation out of the lamps. The light assemblies are sealed and only have a small hole where ther bulbs go in as well as a small vent. The condensation is normal and will come and go. Even if you put a new light assmebly on the car you could still get the condensation. Go to the dealer for the brake pedal pad.
Nov 29, 2008 | 2007 Nissan Altima 3.5 Sedan
change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
377 people viewed this tip
Top Corona Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
