Tip & How-To about Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax
Faint output when printing from Leopard
If your output is faint or if the driver settings and/or features are missing, your system may have automatically added the printer using the Gutenprint driver. Many printer drivers are provided with Leopard but some drivers may need to be downloaded from the manufacturers website.
support.epson.com
www.hp.com
www.canon.com
support.lexmark.com
www.brother.com
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Go to the manufacturers website and select your printer or All-in-One model from the appropriate list.
4. After selecting your Printer or All-in-One, the web page will either confirm that the correct driver is provided with Leopard or give you a description and download option for the correct driver for your printer.
5. If the driver for you model is included in Leopard, skip to step 6. Otherwise, download and install the Leopard driver before continuing with step 6.
6. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
7. In the System Preferences window, click on Print & Fax.
8. Turn on the printer. The system should add the printer automatically.
9. If the printer driver for your model is included in Leopard (not downloaded from the manufacturers website) and the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the drivers provided with Leopard.
Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax Logo
New Intel MacPro + Epson SP R1800 printer + OSX 10.5.2 = Nightmare.
I managed to solve this problem by, probably, doing what I should've done in the first place: Deleting the printer from the print queue and starting again from scratch.
I read the following instructions from a message from Epson and it pointed me in the right direction. It sounds obvious now, but when you think you've tried everything and you've started to pull your hair out, you can overlook what is staring you in the face.
Message from Epson:
Gutenprint driver. Many Epson drivers are provided with Leopard but the
driver for your printer needs to be downloaded from the Epson website.
System Preferences.
click once on your Epson printer to select it.
correct driver.
clicking on the minus button under the list of printers. Click OK to
3. Go to the Epson support website (www.epson.com/support).
4. Select your product model and download the driver for OS X 10.5 Leopard
operating system.
5. Double-click the downloaded file and follow the on-screen instructions
to install the printer driver.
System Preferences.
The message ended there.
If anyone out there is having a similar problem to me, then I hope this thread helps.
All the best. logan
Mar 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
This will be the probem because there's no compatible driver for this newer version of Mac and that's the reseon its not working..
Aug 02, 2008 | Epson Stylus Photo 2100 InkJet Printer
problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
1,753 people viewed this tip
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
