Tip & How-To about Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax
How to conserve color ink when printing only text documents.
First, make sure you have an updated driver installed in your computer. Visit http://support.epson.com for updated drivers.
To select black ink only mode and conserve color ink when printing only text documents, please do the following:
1. Open the Printers window by following the appropriate steps for your operating system:
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click on your printer name and select PRINTING PREFERENCES.
3. Click the ADVANCED tab.
4. Select the BLACK INK ONLY option.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax Logo
need windows 7 driver for epson lq-570e
Epson Support says to use the Windows Update to receive your printer drivers:
1. Attach your printer to the computer.
2. Turn on the computer and the printer.
3. Click on bottom left Windows logo -> All Programs -> Windows Update -> Check for updates -> xx optional updates are available -> Your-Printer-Drivers-Should-Be-There -> Select Your-Printer-Drivers checkbox -> OK -> Install updates.
Sep 27, 2010 | Epson LQ-570e Matrix Printer
bought new computer cannot find disc to install and run my epson stylus cx3600
Go to epson.com, drivers, and look up your model. They don't list a cx3600. Is it a cx3200?
If so, download the drivers.
Aug 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Jul 11, 2008 | Epson RX595 Photo All-In-One Printer
vista cannot regocnise my rx600
5. Try printing.
*NOTE:
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
1,773 people viewed this tip
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
