Tip & How-To about Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax Logo
How to reset nokia mobiles life timer to ''0''
If there is no choice, then try this...this will completely reset your nokia 5700
Note: All your contact on your phone memory will be deleted...even your installed item will be reset... everything will be deleted...i think your memory card will not be formatted but still try to remove the memory card before trying this.
Ur phone must battery must no be low!!!
  1. Turn off Your Phone.
  2. wait for 30 sec, then
  3. press *
  4. press Green button(button that u answer call)
  5. press 3
  6. you must press all the three button at the same time and start the phone
if this dont work, try the same thing again and again...it will WORK!!
Jun 21, 2010 | Cell Phones
Unlock Your Nokia mobile phone with Code Calculator
Hi., Thanks for the information. In my point of view using unlock code is the best way than using unlock calculators and other devices to unlock your mobile phone. There are lots and lots of sites providing free unlock code to unlock your mobile phone. i recommend you to use the unlock code to keep your mobile safe. you can get the free unlock code from more sites like http://www.unlocking4free.com/
These sites are providing unlock codes for mobile phones...
Thanks...
Jan 10, 2009 | Nokia N95 Cellular Phone
10,924 people viewed this tip
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
