Tip & How-To about Nokia N70 Cellular Phone
Standby
With the Nokia N70, there's an 'active' standby screen. Don't just take the shortcuts given, I'm sure you have ideas of your own as to your most used applications. You can change any of the five shortcuts in the rather-hidden-away 'Tools | Settings | Phone | Standby mode | Active standby apps' (Phew, you really have to get to know the settings hierarchy on these devices!)
Nokia N70 Cellular Phone Logo
Nokia 3120 Classi Supportive File Noting to Display
Pada program jika dipilih muncul tulisan "Supportive file. Nothing to display."
Untuk nokia 3120 classic, bisa dicoba alternative ini:
-> Pastikan progam yang hendak dipakai sudah diklik "options" atau bisa diatur dulu "application access"! (Supaya program dapat muncul)
-> a. Pilih "menu-settings-display-active standby-active standby mode (on)
lalu pada posisi standby pada shortcut bar pilih "options-select shortcuts-application list-silahkan pilih programya (ditandai)
pilihannya:
done-done-(save change? Dan pilih "yes"
Lalu pada posisi standbay pada shortcut bar, dipilih program2 yang sudah dipilih
b. Cara yang ke 2 bisa memanfaatkan tombol shortcuts:
"Menu-settings-display-my shortcuts-left selection key atau right selection key atau navigation key-application list-pilih programnya
Pada posisi standby, silahkan dipilih pilihan tombol shorcut yang sudah diatur
*Semoga bermanfaat
Jan 28, 2012 | Nokia 3120 Classic Cell Phone
how do i remove shortcuts on my nokia n95?
You can use the "Settings" app to disable "Active standby" and they'll be gone (along with the application shortcuts on the standby screen; they can't be disabled separately).
Nov 29, 2009 | Nokia N95 Cellular Phone
call from pc with use of my nokia n70
Hello there! thanks for using Fixya.com!
Unfortunately, we cannot use that feature especially as I know with Nokia N70 phone. You can only use bluetooth devices head sets or other supported devices via bluetooth. However, you may use your mobile as a modem and access thru GPRS and you may browse directly from your pc, just connect your phone with USB cable to your pc.
Here some details of the specifications, Here is the detail for this user guide manual: Nokia N70 Help Tutorial Useful shortcuts Clock Clock settings World clock Volume and loudspeaker control File manager View memory consumption Memory low—free memory Memory card tool Format a memory card Make calls Voice calls Make a conference call Speed dial a phone number Voice dialing Video calls Video sharing Video sharing requirements Settings Share live video and video clips Accept an invitation Answer or reject a call Answer or reject a video call Call waiting (network service) Options during a voice call Options during a video call Log Recent calls Call duration Packet data Monitor all communication events Personalise your device Profiles—set tones Offline profile Transfer content from another device Change the look of your device Active standby mode Contacts (Phonebook) Save names and numbers Default numbers and addresses Copy contacts SIM directory and other SIM services Add ringing tones for contacts
for more info, check this site http://www.ebookmanual.net/nokia-n70-user-guide.html
Feb 15, 2009 | Nokia N70 Cellular Phone
nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
nokia n95 sport
Go to the settings menu > general > personalisation > standby mode and turn active standby off
Jul 19, 2008 | Nokia N95 Cellular Phone
1,560 people viewed this tip
Top Nokia Cell Phones Experts
270rexton
270rexton
