Tip & How-To about Bose Car Audio & Video
Basic Vehicle Stereo Wiring
To do it right make sure you buy a wiring adapter so you don't have to cut your factory wiring plug off.
Below is a wiring picture. Not all the wires in be required to hook up because some vehicles don't use them.
Blue/White (Remote Turn on): Used if sub woofer and amp system is being installed
Orange (illumination): Not every vehicle has this .. This is used to dim the radio when the head lights get turned on its own.
Blue (Power Antenna): Only used if you have one
Sometimes there are extra wires on the deck for steering wheel or remote volume control.
Car Audio & Video Logo
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
95 s10 blazer 6 speaker stereo what are speaker wire colors harness was cut 6 speaker not 4 ..dash .front door . Back door
This year never came with 6 speakers (4), so what wiring is installed for those 2 add on speakers I would have no idea.
Here is the factory wire colors from the manual.
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 07, 2016 | Cars & Trucks
I'm trying to install an aftermarket cd player in my 97 explorer when I wiring in the new deck to the speakers they don't no sound comes through the stock speakers is there an app I need to find?
you can buy an adapter the plugs into the factory wiring and the new radio so you don`t cut and butcher the wiring of the car. it covers the wiring for the speakers as well. going by your photo this looks like a bad wiring and splice job.
Sep 01, 2015 | Cars & Trucks
what is the wireing colors for the radio in a 92 jeep cherokee larado
All vehicles wiring is the same.
To do it right make sure you buy a wiring adapter so you don't have to cut your factory wiring plug off. Below is a wiring picture. Not all the wires in be required to hook up because some vehicles don't use them.
Feb 07, 2012 | 1992 Jeep Cherokee Limited
I have a 1997 Aerostar and would like to wire for trailer lights. I opened the panel on the left side just in front of the tail lights and found a couple wiring receptacles. Are these for trailer wiring? Thanks, Rick
if they have color coded wires that are brown,green,yellow and black then its possible.but i don`t think so.you can buy a trailer wire adapter that just plugs into the car factory wiring so you don`t have to splice(solder) the wires into the car wiring and it will show you the area for the connection and picture.if you don`t want to go that route then the tail light wires colors are brown.the left signal color is yellow and the right is green and the ground wire on the car is black but on the trailer wire harness it is white.
Apr 12, 2011 | Ford Aerostar Cars & Trucks
1,560 people viewed this tip
Top Bose Car Audio & Video Experts
xxxxxx xxx
Tina Robinson
_ST_
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
