Tip & How-To about Fisher and Paykel IWL12 Top Load Washer
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
Fisher and Paykel IWL12 Top Load Washer Logo
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
GWL11 Burned Up?!?!
Go and look at my issue on Eco Smart that won't drain.
Unplug washer. Bail out water as much as you can. Look for water dripping in black motor area. If you find that, read on to see if this is your issue.
You can take off black motor/white housing all in one piece. On mine, water was dripping from white plastic housing and onto motor. had small amt of water leak out, then wouldn't run at all and smelled like electrical issue. Look for white chip on upper rim of that white plastic housing where it attaches to machine bottom. Push in on clip, and give the whole white plastic thing a twist and it comes off--motor and white plastic. Unhook electric couplers.
You either have 120V or 240V (mine is older GWL10US model) unit. White plastic and black motor are one unit when ordered. Save yourself the service call that I paid. Good luck!
Oct 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
2,147 people viewed this tip
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
