Tip & How-To about Kodak EasyShare V603 Digital Camera
Lense sticking with good battery?
If you have a Kodak EasyShare V603 and have the lense sticking or not retracting all the way when you power down with a known good battery, this tip may save the day for you ...
Note I said MAY save the day, NOT "will" ... Nothing in life is certain ...
The extending/retracting lense assembly is very sensitive to dust or foreign material. If even the slightest amount of dust... pocket lint, anyone?... gets inside the camera housing in the area of the lense mechanism, the sticking can occur...
the solution is to undo the screws holding on the front half of the housing and get that shell out of the way... then run a clean q-tip around the outer rim of the lense assembly ...
filthy, isn't it? ... now repeat... once your q-tip comes up clean, blow away any residual dust. The jury is out on whether alcohol helps at all here ...
Repeat the procedure to clean the opening in the camera housing through which the lense extends as well ...
Reassemble the housing and you MIGHT be good to go ...
Of course, if you dropped the camera into the La Brea Tar Pits, don't expect a miracle, but this procedure can get rid of a surprising amount of dirt & dust that can build up inside the camera from carrying it in your pocket or purse ...
I DID say you need a known good battery, right ? oh, and it helps if it is fully charged too ...
Worked for me !
Kodak EasyShare V603 Digital Camera Logo
HELP!! I am having a real Kodak moment. I have a Kodak M883, The wall charger says the battery is full but when you put the battery in the camera the camera turns on, the lense extends, battery reads empty, the lense retracts and the camera shuts down.
Hello :
It seems that the battery is dead or the battery base is rusty or there's isolation stuff on it . Try to clean the base first . If that didn't help , then I recommend you to replace the battery .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kodak EasyShare M883 Digital Camera
Lens won't retract, stuck in outward position
battery power/and or lens motor/ if lucky the lense connection, (Try removing the lenses and puting them back) may be a bad electrical connection.
Aug 11, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
camera V603
the camera should be brought to a repair shop since it might be a mechanical problem or parts may need to be replaced already.
Aug 25, 2008 | Kodak EasyShare V603 Digital Camera
Zoom and camera shuts off
Verify you have the right kind of battery and fully charge it.
The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
Apr 27, 2008 | Kodak EasyShare One Digital Camera
3,117 people viewed this tip
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
