Tip & How-To about Technics Audio Players & Recorders
How To Adjust the pitch & brake
1.switch off deck & unplug it.
2.take off slip matt & place fingers in the holes, then twist & pull until platter comes off.
3.undo the 4 or 5 screws which hold the plastic dust cover on.
4.at the top right of the board theirs two pots labelled "PITCH" & "BRAKE" mark them both with a marker pen before you adjust them.
5.turn the brake or pitch pot clockwise to tighten/speed up & anticlockwise to slacken/slow down.
good luck:
teac schematic
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Stylus city
Jul 03, 2014 | Teac Audio Players & Recorders
sony PS-lx250h
Most likely the belt has come off or is worn.
Job done.
Jul 02, 2014 | Sony PS-LX250H Turntable
change belt on rotel 310 turntable
Job done.
Jul 02, 2014 | Audio Players & Recorders
platter reverse when stopping
The brake needs adjusted.
depending on your conference, i can talk you through it.
2.take off slip matt & place fingers in the holes, then twist & pull until plater comes off.
3.undo the 4 or 5 screws witch hold the plastic dust cover on.
5.turn the brake pot clockwise to tighten & anticlockwise to slacken.
in your case you need to slacken it off just a touch.
good luck:
Jan 29, 2012 | Technics SL-1200MK2 Turntable
how to replace the speed pitch
Take off the platter by pulling up on the 2 holes under the slip matts. Flip it over. Twist off the feet. Take out about a thousand screws. And the black ruberish section should come right off. There are 2 screws that hold the pitch in place. Unplug it! plug the new one in! It real simple. If its an old 1200 and you can solder....Replace the RCA jacks as they to wear out. Good luck! And if you need me just message me!.
Mar 27, 2010 | Technics SL-1210 Turntable
1,373 people viewed this tip
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
