Tip & How-To about Acme 5001 Supreme Juicerator Juice Extractor
How to keep your juicer from jumping all over the place.
I have found celery is the big problem, instead of putting in the whole stalk cut
it into small 2 inch pieces, when I do this I have no problem, otherwise my
juicer is jumping all over the counter. I believe it is the long strings in the
celery that somehow gets caught around the parts. At least it has made
juicing a pleasure for me. Hope it works for you.
If this has helped you please let me know, mlesueur2000@yahoo.com
Acme 5001 Supreme Juicerator Juice Extractor Logo
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and carrots. I've been reading and it says that it could be the blade needs to be changed? Please, help. Thank you.
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
Apr 22, 2011 | Acme 6001 Juice Extractor
when i juice greens i am no longer getting any juice from them. is my blade dull?
If you mean green leafy greens, the juicer is
not really designed for them. A sharp blade
will extract some juice from them, but I found
a new blade seems to increase the vibration
issue. Acme works best on carrots, apples,
celery, etc.
Oct 25, 2010 | Acme 5001 Supreme Juicerator Juice...
shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
1,594 people viewed this tip
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
