Tip & How-To about Microsoft Windows XP Home Edition
FTP Default Ports
For those of you who trying to set up a ftp ( file transport protocal) utility for the first time, the default access ports are port 21 and port 22.
anaanymous
Microsoft Windows XP Home Edition Logo
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
set up ftp server behind the router
you need to set port forwarding for the correct ports, the default port number is 21. so you need to forward port 21 for 192.168.1.50
then go to www.whatismyip.com
copy your ip and add" :21 " without the " " in to the address so it looks something like this: 85.76.240.1:21
now your friend should be able to login from internet explorer for examble after typeing ftp://yourip:21 or from my computer by typeing ftp://yourip:21 into the address bar.
if you need more assistance let me know. im here to help.
Also if you are intrested we can try remote assistance to solve the problem but I would like some compensation for my time with remote control.
Apr 14, 2008 | Linksys Wireless-G WRT54GS Router...
FTP problems.
There are 2 ports used for FTP. They are 20 and 21. When you initiate a connection that occurs on port 21, but data traffic is on port 20. Your firewall sees your outside FTP server trying to 'initiate' a connection on port 20 and breaks the connection to that IP address.
What you need to do is either use 'passive' ftp or open both ports 20 and 21 for ftp traffic in the firewall.
Apr 02, 2008 | D-Link DFL-800 Firewall
319 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
