Tip & How-To about Belkin F8T030 Bluetooth Access Point w/ USB Print (814227018805)
Installing a printer on the F8T030 Bluetooth AP in Vista
This worked for me...
Install Printer Driver on PC
Select driver properties - then PORTS tab
Add Port
Select "Standard TCP/IP Port" then "New Port"
Next on Wizard
Enter IP address of AP (ensure you have a fixed IP address)
Port name can be anything unique (I used "Belkin_USB2")
NEXT
Wizard will search but not find anything.
Under Device Type select Custom and "Settings")
Set Protocol to LPR
Set Queue Name to "upper" or "lower" depending which USB socket you have used on the AP
Ensure "LPR Byte Counting" is enabled - this is important.
OK
NEXT then FINISH and Close "Printer Ports" dialogue.
Apply settings and try test print.
Worked ok for me (Vista Ultimate 64)
Belkin F8T030 Bluetooth Access Point w/ USB Print (814227018805) Logo
i WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error stated in the printer properties. Netgear have not helped, can anyone!!?????
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
well you please tell me default IP address of LINKSYS Wireless-G Print Server
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Jan 22, 2009 | Linksys Wireless-G WPS54GU2 Print Server
I need a new port
remove old router software, and it should open that port..then start from the beginning on installation of new router, then connect your printer.
check your computers warranty here 4 FREE
Mar 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
744 people viewed this tip
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
