Tip & How-To about Lian Li Industrial Co. PC-65B ATX Mid-Tower Case
Changing 80 mm Fans
Note that the stock "ADDA" fans are mounted with Lian Li plastic mounting hardware. (4 Clips.) If you remove them gently by pressing from the pins out and then pulling the pins out completely the mounts can be re-used for your new fans.
Lian Li Industrial Co. PC-65B ATX Mid-Tower Case Logo
pc75-1. How do I flush hydraulic system?
Lian LI PC-75 work log. {56k beware} ' Overclockers Forums
www.overclockers.com/.../523704-Lian-LI-PC-75-work-log-56k-beware
Aug 18, 2007 - 13 posts - ‎9 authors I will be using the Lian Li PC-75 for the watercooling build. ... After about 1/2 hour with a jigsaw and dremel the finished product. ... Vapo sides for me so that they will be 4 inches longer and fit flush with the Lian Li PC-75 ... Will go higher now that I am runningcooler but for the purpose of the tests this works ...
Oct 14, 2015 | Cars & Trucks
heatsink
INSIDE A COMPUTER OR THE HEAT SINK FOR YOUR COMPAQ COMPUTER?
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer. Processors are very finely engineered components that are not repairable. But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer. Just check with HP/Compaq for the correct and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the cover. Lay the computer down flat. If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs. Examine the processor assembly. The processor is a square chip that is covered by a metal heat sink with fins. A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard. Two clips usually secure the heat sink assembly to the top of the processor. Gently press down and slightly away on the flat end of a clip to release it. Avoid using a screwdriver to release a clip; a slip could scratch the motherboard. Release the clips and gently remove the assembly. The heat sink should separate, leaving the processor behind in the chip holder. Clean the bottom of the heat sink. Use a paper towel and a dab of solvent cleaner to remove the old thermal paste. Set the clean heat sink aside. Lift up the lever to unlock the old processor and remove it from the pin mount. Insert the new processor chip. Align the pins on the processor to the "cut off corner" or dot on the pin mount. The processor should drop into the pin holes easily. If the processor won't drop in easily, check the pin alignment. Once the processor is inserted correctly, pull down the lever to lock in the chip. Apply thermal paste to the bottom of the heat sink. Apply enough paste to cover the area of the small gray rectangle on top of the processor. Apply the paste with a spreader made from a piece of flexible plastic. Spread the paste evenly to a thickness of two sheets of paper. Check the heat sink mounting alignment and lower the heat sink onto the top of the processor. Reinstall the mounting clips. Reattach the heat sink fan to the motherboard if necessary. Plug in the computer and monitor and boot. If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully. Shut down again and replace the exhaust fan hood. Close up the computer and reboot. Hope this helps.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=thermal+paste
Jan 19, 2013 | HP Compaq Presario SR5610F Desktop PC
bad processor on my hp compaq
Just check with HP/Compaq for the correct size and speed of processor for your motherboard before purchasing a replacement.
Remove the cover.
Avoid using a screwdriver to release a clip a slip could scratch the motherboard.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps
Nov 11, 2012 | HP Compaq dc5100 Microtower PC Desktop
Need a special Lian Li fan
Most computer stores will have one that will fit, although it may bot look the same. Take the old one with you to compare.
Mar 26, 2010 | Lian Li Industrial Co. PC-65B ATX...
viewsonic vg2021m base mount
Gently lay the nonitor, face down, on a table such that it will not be damaged while you remove the base. You will find a curved strip of plastic about 1 1/4 inch wide and 4 inches long. Near the center of this strip, you will find two parallel plastic ridges. These are clips that hold the base to the monitor support post. Squeeze these clips together to remove the base from the support post. I was able to squeeze the rear strip toward the rear of the base and ease the rear of the base off that clip and it came apart ok. It is a bit tricky, but doable. Good luck.
Orval
Dec 08, 2008 | ViewSonic VG2021m LCD Monitor
877 people viewed this tip
Top Lian Li Industrial Co. Computers & Internet Experts
David Payne
David Payne
Are you a Lian Li Industrial Co. Computer and Internet Expert? Answer questions, earn points and help others
