Tip & How-To about Epson TM-T88III Thermal Printer
Printer : Checking the printer
Check the lights on the printer
Power in solid green - printer is in ready mode, else:
  • disconnect and try another power source or power-adapter.
Paper Feed in solid red - no paper:
  • make sure paper is of the correct type and dimension. re-seat the paper.
Error in solid or flashing - hardware problem:
  • turn off the printer.
  • open and access the DIP switches, make note of the current settings, then set it all to zero.
  • remove the Connect-It module at the back and re-install it.
To test the printer do the following:
1. Disconnect the printer from the computer.
2. Turn the printer off. Make sure that there is paper and properly loaded.
3. Press and hold the Paper Feed button while turning the printer back on.
4. A self-test print-out that contains information such as firmware version and settings depending on the detected connection type.
Epson TM-T88III Thermal Printer Logo
my wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
how to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
What does it mean when there is a solid red Power light on the ATT 2wire DSL wireless router?
it means 2 things. 1st it could be the adapter because theres still power to it and 2nd is the 2wire router is already defective. if its possible for you to bring the 2wire with the adapter to any computer store or to att store and have them plug a new adapter on it . or if you have available 5volts adapter you can try to check if power will be solid green using diff adapter definitely its the adapter but if you have tried it but power will flash green or red the modem is dead. powerlight of any router should stay solid green no matter what happen.
have it checked carefully so you dont need to spend $82 for the 2wire, adapter is $10 only..
Sep 26, 2009 | 2wire (1000-400108-001) Router
no power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
2,608 people viewed this tip
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
