Tip & How-To about Computers & Internet
Writing scripts for doing regular stuff again and again
This tip is mainly useful for software professionals.
If you are doing some stuff regularly on your server, say checking out code from server and building it, then do these steps using scripts.
This has few advantages:
1. You need not type the same instructions again and again
2. This will speed up the things you are doing.
3. You can just initiate the script and parallelly do some other stuff
4. This will enhance your scripting knowledge.
Computers & Internet Logo
Suddenly am unable to connect to internet
As for me...
I use the flash-light flip up control...
and BLUETOOTH... and my WAP both fall full victim to my larger than life finger tips...
CERTAINLY I'm just saying where I check first.
After that... go into settings
First.. check AIRPLANE MODE is "OFF"
Second check the WiFi is "ON"
Its all good... your INTERNET Service Provider IS DOING SOMETHING TO YOU... Give them a call
Jan 16, 2016 | Apple iPad Mini
Fix corupt messages exchange 2010 mailbox
I would say try moving users mailbox to see if that would help if not then no other option than to Restore from backup.
If doesn't help, look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/exchange-server/734-repair-exchange-priv1-pub1-edb
Or: Exchange Server Repair Kit is an absolute must-have for any software development professional working with MS SQL databases.
For more information: http://www.exchangeserver.repair/
Dec 21, 2014 | Microsoft Exchange Server for PC
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
Hi, I've got proliant ml110 g4 server, itel
you keep posting this.
why use any server to play games.
why not build a real DT with ASUS top MOBO.
why mess with this old rig?
why run XP the virus magnet and is Dead OS for 3 years
missing Service pack 3? that is hopeless too.
Vista too is DEAD> OS.
put in windows 7, if it can run at all , ask HP that. HP.com
ever heard of them?
and last (BAD NEWS HERE)
expansion RoM
your server class BIOS does not support , expanded external
video carD ROMs , like all real DESKTOPS do.
your card USES this spec, PC , PCI slots only.
PCI Express 2.1
the card use that spec, for voltage levels
and is dual level (low) card.
you system uses 3.3v and is not supported by that card. period.
ask HP what Express card levels it can use if any.
ask on the HP forum, (google HP forum, its not HERE)
An Oxymoron:
bios is NOT IN XP, ? BIOS is not OS. at all.
they do talk back and forth yes.
BIOS.
it's ROM on the the mother board, only, and on all highend'
video cards, (called expansion rom on the card is this ROM) this error can be the above, wrong card
and when reading the rom gets errors due to wrong signal levels used. (2.1 cards are wrong here)
you sound NOOB'sh, that's ok.. this stuff is easy.
Bios is just rom code, read only memory chip
you take out the HDD on aNY PC AND THE ROM WORKS
PERFECT IN ALL CASES.
With no MOBO rom , you cant boot, nor decide what to boot or order.
my guess is you fell in love with the word server or
the game you have has a published minimum system spec
did you read that first? it will be laggy on that level of system.
first G4 was 2004? what year is yours?
HP says it runs windows 7 , 64bit. not XP. ever.
http://h20566.www2.hpe.com/portal/site/hpsc/template.PAGE/public/psi/manualsResults/?sp4ts.oid=3186395&spf_p.tpst=psiContentResults&spf_p.prp_psiContentResults=wsrp-navigationalState%3Daction%253Dmanualslist%257Cviewall%253Dtrue%257Clang%253Den&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Intel®Xeon®3000 series processor
3040 PROCESSOR, WITH 2 cores.
the slowest one made it seems,,, old it is.
slots
One PCI-E x8 slot
One PCI-E x4 line with x8 slot
Two 3.3V 32-bit/33-MHz PCI bus slots
only 3.3v video card work here if at all, BIOS may not.
no card stated by you, so no help .
what ever card you use must make the PCI bus happy
it most be compliant with that PCI buss chip, there.
that means only old card work there, period, real old.
http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=3186395&docLocale=en_US&docId=emr_na-c00795605
tell more get more
id never attempt what you are doing
it's for a server, never a VIDEO game platform
what games in the future do you want to run?
that matters FIRST.
and last UPDATES
do not use XP, ever.
HP does not support older that 10 year old systems
for sure not XP, its a Dead OS now.
if MS cant support it how can HPnor is your video card maker support Dead XP !
use Windows 7, forget all older systems and have a chance at success.
there is no bios upgrade on old systems.
unless super lucky, I dont have your service tag so cant help much.
go to hp.com
enter your service tag number and read all these facts.
Mar 27, 2017 | HP Compaq ProLiant ML110 G4 Server
I forgot my sql server password, and i need to get the sql sa password back, how can i retrieve my sql sa password? its SQL server 2005. Any advice is ok, i dont want to reinstall the SQL server, Thanks in advance.
Lost or forgot your administrator/user password for Microsoft SQL Server?
If so, turn to help from AnyPasskey SQL Password Recovery, which is a professional program enables you reset administrator or user password for Microsoft SQL Server instantly regardless of the length, complexity, language and encoding of the password set before. As long as you got AnyPasskey SQL Password Recovery and master.mdf file, you could reset SA password on any authorized PC in minutes without the installation of Microsoft SQL Server. What's more, this featured-in tool supports all versions of Microsoft SQL Server and Microsoft SQL Server Express perfectly. 6_21_2012_1_55_07_am.jpg
Sep 15, 2010 | Computers & Internet
463 people viewed this tip
David Payne
David Payne
