Instruction applicable for all
Window XP system,
For Any Brand and Model PC, whether it is of
DELL/
HP or any brand ..
Applicable to
Desktop PC as well as
LAPTOP
If your system hangs about 5 or 10 minutes at
Startup/Bootup,
And if you can't access the Start button or the Taskbar, most oftenly one of the specific service (Background Intelligent Transfer) running in the background.
Microsoft generally gives a patch for this but usually not work for in most of the cases
So please try this method, it is almost easy with no harm to PC.
- Click on Start
- Open the Run window,
- Type msconfig, then click 'OK'.
- Go to the Services tab, find the 'Background Intelligent Transfer' service.
- Disable it, apply the changes & reboot.
Next time you reboot the PC it will show System Configuration Utility window, place a
Tick Mark in
check box and then OK. SO that it would not appear again.
Also one more thing you can do Go to MSCONFIG and in the Startup Tab
Disable the items which you think
not necessary to come during startup.
THis will help you lot to
reduce the time being taken in
Startup.
Hope it will work for you.
With Best wishes
Ellin Scott
