Tip & How-To about Garmin nuvi 350 GPS Receiver
Lost PIN for Garmin Lock - Nuvi Series
I've seen many postings from users who say they have lost their PIN code.
For those of you that don't know what a PIN code is:
Garmin provides a feature called "Garmin Lock", which allows the GPS owner to assign a (4) digit numeric unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
The PIN setup can be accessed by pressing the "wrench" symbol on the main menu (Nuvi Series). Next, press the "gear" symbol and you should see a listing for Garmin Lock.
When you set up the PIN, you will be asked to enter in a (4) digit numeric code. After you enter the 4th digit, you will be asked again for the code. This is to make sure that both entries match and that verify that the PIN that you request will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing the GPS apart.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgot both the PIN and secure location you are out of luck. You'll have to send your unit back to Garmin to have it unlocked. Garmin may charge you for this service.
Note: If you do send the unit back to Garmin to be unlocked and you are found not to be the original owner of the GPS and it's determined to be stolen, Garmin will contact law enforcement (they're policy on this is right on their website under FAQ's).
- Jim
http:///www.sharcnet-usa.com
Garmin nuvi 350 GPS Receiver Logo
need user manual huawei m615
i dont think user manual is provided extra...
otherwise please comment below and rate my answer 5star ..telll me your problem or anything you wanna know about it and i'll help
Dec 01, 2011 | Cell Phones
GARMIN C550
Hi Don,
You probably just need to find the reciept where you bought the C550.  Sounds like Garmin is protecting its customers when they say $300.  This is most unfortunate thing to happen to you.  Is the Garmin $300 issue as I thought and related to you not having the registration code or Reciept?
Oct 13, 2007 | Garmin StreetPilot c550 GPS Receiver
lost pin code
Your nuvi has Garmin Lock activated, a security feature to make the unit useless to thieves and to protect your data if the unit is lost.
Unless you know the security location used when the pin code was set, or can remember (or ask the last owner for) the pin code, then your unit cannot be used without sending it back to Garmin (proof of original purchase required)..
Click here and you'll see my FixYa Tip regarding this common problem. If the hyperlink doesn't work then cut and paste the following link into your browser:-
http://www1.fixya.com/support/r6051291-when_forget_garmin_pin
Sep 28, 2011 | Garmin Nuvi 610 GPS Receiver
6,629 people viewed this tip
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
