Tip & How-To about Soundstorm SDVD-900 Car DVD Player
How i get a manuel to install
Is true that it need to be conecter to the hand brake to be able to watch a movie how i get a manuel
Soundstorm SDVD-900 Car DVD Player Logo
I just set up my Pioneer AVH-P4100DVD in my 2001 GMC Sierra and I cannot watch DVD's. The DVD reads, but nothing appears on the screen. Additionally, it shows the warning symbol regarding driving and watching movies. Any suggestions?
read the manuel, there is always some way to turn off this feature
i.e. if the player thinks the car is on it might it assume its being driven
other than that mess around with the options
May 08, 2010 | Pioneer AVH-P4100DVD Car DVD Player
what can i do to wacht dvds?
you must have connected the safety feature to the hand brake.
this disconnects the dvd from working until the hand brake is applied. you will need to attatch this wire to a ground connection to enable it to be played while moving
Apr 06, 2010 | XO Vision GX1046 10.4 in. Car Monitor
My pioneer avh p5700 won't display movies what should I do
this is a security feature integrated in the player, when u are moving(handbrake is off) u shouldnt be able to watch movies, well unless u have the ability to drive SAFELY and watch a moie, witch i do doubt about. green wire should be connected to the hand brake sensor. or just make a small switch(not more than a couple of pounds or just brake any unusfull appliance that has an on/off switch and use it :-)) ( one end connect to the wire and on the other side to any metal part of the chassi - do NOT connect with positive!!) put it on a easy location and every time u start ur car have to turn the switch off and then back on this way the player thinks u are not moving and the hand brake is on.
REMEMBER, DO NOT TRY TO DRIVE AND WATCH MOVIE SAME TIME AS I DO KNOW PEOPLE TRYING TO DO IT, IF U WANT ADVICE FROM SOMEONE THAT HAD AN ACCIDENT FOR THAT REASON, A CAN PROVIDE U WITH THE INFORMATION U NEED !!!!
Mar 08, 2009 | Pioneer AVH-P5700DVD Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
467 people viewed this tip
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
